Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-02-2003, 08:48 AM
gs1344 gs1344 is offline
94 Jimmy Fuel Pump Problem
Can not hear the fuel pump run, prime, no pressure. The relay is working, We changed out the fuel pump without luck, still does not prime on key start. Checked and the pump has 12v at the harness with ignition on....... I have no clue what the cause is. Anyone have an Idea?
Old 12-05-2003, 11:05 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 94 Jimmy Fuel Pump Problem
Did you plug up the pump connector inside the tank?
Happens to the best of us.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-05-2003, 12:22 PM
Unfortunetly, we did plug it in. We did notice that the old pump wire connector was brown from age/heating. And of course we never thought to plug the new one in once installed into the harness outside of the tank to see if the new pump would come on. Everyone seems to be of the opinion that the problem is in the pressure sensor etc but am I crazy? if the wire harness at the tank has 12v then ... the pump should run! ? !
Old 12-05-2003, 01:37 PM
GMMerlin's Avatar
I know stuff
Re: Re: 94 Jimmy Fuel Pump Problem
The brown from age and heating is a result of the wire overheating due to a loose connection...the female terminal can widen over time and cause an excessive current draw due to poor terminal contact.
If you have 12v at the connector to the tank, then the control circuit is working to that point.
You need to look at the wiring inside the tank and the ground circuit.
There was a ground wire that was bolted to the rear frame crossmember by the bumper...check that.
GM WCT
PM Me for details
Old 12-06-2003, 08:31 AM
Re: Re: Re: 94 Jimmy Fuel Pump Problem
GMMerlin - you were right on the mark. Thank you for your help! We dropped the tank and pulled the core assembly again. As we tested starting at the connector we found that the connector pins were no longer making a good connection. A wire assembly is needed.
Thanks again!
Closed Thread
