Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 12-01-2003, 10:54 PM
walta walta is offline
Send a message via MSN to walta
Question Will 33's fit under my Z71
I have a 1993 chevrolet Z71 with a 2 inch bod lift and im lookin to put new tires on. Will 33's fit under there and also should i get bfgoodrich M/T, Goodyear Wrangler M/TR, or Maxxis mudder buckshot??
Old 12-02-2003, 04:46 PM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
The only way to know is to get in there and measure. With a lift that should give you more options for tire sizes. I would check with the shop installing the lift kit to see what sizes they have run with that setup. They would know better than anyone what sizes will fit with the lift kit they are installing.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 12-15-2003, 07:27 PM
jkinney jkinney is offline
I have a 93 Z-71 with a 3" body kit, I purchased it this way. It had 305-65r16 on it, and the turn radius sucks. I have also noticed the insides of my tires rub, so there is no positive stop in suspension while I turn the wheel "all the way" The tires do it (not good) The tires are expensive (I had to replace one when I purchased truck) 195.00...... I'm in the market for a new set of tires and rims now. Looking at a set of take-offs from the 99-2002 with a set of Kelly's LT265/75R16 TRAILHANDLER COMMERCIAL LT. I like the tread pattern, and they are value friendly.
Old 12-15-2003, 09:40 PM
CBmudmonkey CBmudmonkey is offline
Re: Will 33's fit under my Z71
yes you can fit 33's under your z71 my friend had a 91 z71 with 3in body and has 36in superswamper tsl's....the buckshot tires have been working for me really good i have put about 6000 miles on them and there is hardly and tred ware
Old 12-24-2003, 08:52 PM
ND4SPD_04 ND4SPD_04 is offline
GET THE BUCKSHOTS!!
