Old 12-01-2003, 10:51 PM
CODE4 CODE4 is offline
Send a message via ICQ to CODE4 Send a message via AIM to CODE4
poll: power steering fluid or ATF?
Just curious what you guys out there run in your powersteering system. My Chilton's manual says something about ATF II (which has been superceded by ATF III) but when checking the dipstick it looks pretty clear to me that it is not reddish-pink.
What have you guys used?
______________________________________________
1999 Eclipse RS
ET: 16.1 @86.241 | Speedworld Motorplex, Phoenix, AZ
Old 12-01-2003, 11:05 PM
NeonblueEclipse NeonblueEclipse is offline
Send a message via MSN to NeonblueEclipse
Re: poll: power steering fluid or ATF?
i use atomatic tranny fluid
seems to be working fine
Dustin
GSX baby!!! ALL THA WAY
Old 12-02-2003, 08:36 AM
laurin1's Avatar
laurin1 laurin1 is offline
Send a message via Yahoo to laurin1
I use STP Power Steering + Stop Leak (as mine starting leaking a while back), and it works (no more leak.)
Old 12-02-2003, 05:46 PM
I used a hand-vaccuum pump to siphon out my PS reservoir and that screen/filter had some black sludge in it (gross). I was at work at the time so I took the screen out and hosed it with brake cleaner to dissolve the shiz and rinse it out, it worked well. As for the old fluid is was dirty and definitely not ATF, so I cleaned it out, and filled up with Vavoline Synpower Synthetic Powersteering fluid (clear with a purplish tint) and started it up. Turned the wheel lock to lock about 10 times then shut if off. Topped it off and it workms great, smoother than before. If anyone does not have a hand vaccuum pump, I suggest getting one, they are EXTREMELY handy in cleaning out master cylinders, slave cylinders, etc. It cannot hurt to replace your fluids every few months or so.
Cannot find a vaccuum pump?
http://www.harborfreight.com/cpi/cta...emnumber=39522
for 30 bucks it is worth it.
1999 Eclipse RS
