1999 GMC Jimmy 4WD selector
All the 2/4 WD selector button lights are lite. I cannot select from 2 WD to 4 WD or etc. The vehicle is running OK in 2 WD. I can't find where the control module is located nor can I figure out how to solve this problem. Has anyone had this problem? HELP!
Re: 1999 GMC Jimmy 4WD selector
yes
OK how did you correct the problem?
Re: Re: 1999 GMC Jimmy 4WD selector
IT POPS OUT EASILY IF YOU GENTLY PUT A STRAIGHTENED PAPER CLIP BEHIND END AND PRY OUT- JUST SWAP THE WIRE TO NEW SWITCH AND REINSTALL |
Thanks for the input. I haven't had a chance to replace the panel, but when I do I'll post the results.
I believe I have the same problem...'98 Jimmy. 4WD buttons blink after pressing 4HI or 4LO, and then go out. Seems to work fine in 2WD, but can't get 4WD to work properly. Seems like electrical problem. Would like to know if you have any luck after replacing the switch. I'll do same when I get fixed.
it solved my problem-It took 5 minutes to replace and the switch costs about 30-40.00. The switch just pops out- I used a straightened paper clip-I gently pried top out and it comes right out- I wire plugs into switch- it was easy.
on my girlfriends all the lights stay light. BUt the 4WD seems to work.
What is the switch called that i need to order? Thanks |
