Old 12-01-2003, 09:38 AM
93civic$racer 93civic$racer is offline
Question 93 civic dx tranny??
cable or hydro??????
Old 12-01-2003, 11:13 AM
JakeDrummer JakeDrummer is offline
Send a message via AIM to JakeDrummer Send a message via MSN to JakeDrummer
its a hydro
94' Integra GSR - Built and Boosted.
95' GMC Sierra 1500 Z71- Business Vehicle.
89' GMC Sierra 1500 4x4 - NV4500 Donor, Mud truck.
94' S-10 - Winter Beater.
98' Jetta - Wife's Car.
81' Kawasaki LTD440
OLD/SOLD CARS: 93' Civic (Sold 124k) -- 91' Civic (Dead 300K) --
91' Civic (STOLEN) -- 92' Civic (Donor) -- 90' Caravan (Dead 227k) -- 89' Civic (Sold 289k) -- 90' Accord (Sold 265k) -- 96' Corrola (Dead 174k) -- 99' Beetle (Sold 134k)
Old 12-01-2003, 11:35 AM
ok, i have a 92 teg ls swap wit a cable tranny...when i do the swap wat would have to be changed???
Old 12-01-2003, 11:50 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: 93 civic dx tranny??
You're going to have to change the tranny to a hydraulic B series, or get a conversion kit to run a cable clutch in your car. www.hasport.com has them
Old 12-01-2003, 12:01 PM
well i want to boost the motor and i will probably be running an ls/vtec...would the cable tranny keep the compressor spinning the hydro or should i go just go wit da hydro??? also i have a the motor sitting my friends shop and i plan on gutting it tomarrow...after i get it machined and the new internals installed should i drop it in or just go ahead and do everthing all while the motor is out???
Old 12-01-2003, 12:03 PM
i meant to say (*like* the hydro)
Old 12-01-2003, 12:09 PM
Before you go boosting, you should look into how you motor and it's parts work. There is no spinning of hydraulic anything, hydraulic means it uses fluid to actuate it, not spin turbine to power a town.
When you step on the pedal, it pushes fluid, which builds up pressure, and moves the slave cylinder to push the shift fork, and so on.
Old 12-01-2003, 12:18 PM
Re: Re: 93 civic dx tranny??
i guess u missunderstood wat i said...i do know how my motor works and wat spins.....also wat i meant was once i go turbo i want a tranny the keeps the compressor (IN THE TURBO) to keep spinning...wat i was asking was, is the cable tranny as affective as the b series hydro...
trannys comaparing are....94+ hydro ls tranny vs. 92 cable ls tranny?
Old 12-01-2003, 12:39 PM
Apparently you have no idea how a turbo works, your tranny, DOES NOT SPIN A TURBO. Turbos are driven off of exhaust gas from the motor. You can be parked in neutral and hit full boost.
Old 12-01-2003, 12:41 PM
Now if you are talking about whether the gearing of the tranny has shift points that let you take advantage of full boost, and powerband, then no there is no difference.
Old 12-01-2003, 12:43 PM
for an anaology a hydro trany works like the brakes on your car. hydro is better than cable i would have to say. its smoother for one thing and i would think it would be stronger and more dependible.
81' Kawasaki LTD440
Old 12-01-2003, 01:51 PM
that is exactly wat im talking about...and thnx for answering my question i appreciate it....so i should just keep the cable tranny...and get the linkage conversion???
Old 12-01-2003, 01:53 PM
also does one tranny have longer gearing then the other???
Old 12-01-2003, 01:56 PM
IMO, you should sell the cable and get a hyraulic B series tranny, a GSR, or B16A would be good, or an ITR if you have some cash.
As far as tranny gearing, it doesn't matter if it is hydraulic or cable, it matters what model it is. The vtecs trannies have shorter gears for more sporty driving, while the non vtecs such as the LS/RS/GS, tc.. have longer more highway friendly gears.
Old 12-01-2003, 02:29 PM
well hopefully when this project is complete i wanna run low 12s on street tires with race gas..and alot of people say the ls is better because it keeps the t3/t4 (which i plan on getting) at full boost for a little bit longer...so when u make that shift to 2...3...4...then 5th u get that full blast of bone crushing torque (being sarcastic) hardy har har....but i could be wrong...
