Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-01-2003, 06:04 AM
Nalfein Nalfein is offline
RB26 head on an RB25 and other stuff....
Will an RB26 head fit on an RB25?
I'm asking cause I wanna do an RB25 swap into an s13 but I've heard the 26 head revs better...
What about internals...? I know the 26 internals ie: crank, rods, pistons are stronger will they fit in the 25 (and how will the change specs like compression and displacement) or would it be cheaper and/or better to find some after market rods pistons for the 25. I plan on making 500 hp.
Where could i get a hold of some after market internals for the 25?
By the way my names Matt, I'm 20 and new to this forum... just trying to tap into this deep well of Nissan knowledge before i go and spend a shitload of money.
Thanks in advance
Old 12-01-2003, 06:27 AM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
just build up the 25 head with some aftermarket valvetrain pieces, will rev better then a stock 26 head.
Old 12-01-2003, 06:32 AM
Re: RB26 head on an RB25 and other stuff....
valve train parts from where?
Old 12-01-2003, 07:38 AM
Banned
I dunno, I've never looked into building up a RB like that. You would most certainly have to look in Japan for those kind of parts. JUN, HKS, or Nismo would be a place to start. I would suggest getting some aftermarket cams, stronger lighter valve springs and retainers. The cams would help out the top end and make it rev quicker. The upgraded springs and retainers would allow for a higher redline.
check out takakaira.com for some parts, its sort of vague but I have no idea where to get parts for a RB.
Old 12-01-2003, 07:48 AM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
If you want a higher redline, then get those upgrades^
If you just want it to rev quicker then all you need is some lighter pullys and a lighter flywheel.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 12-01-2003, 11:34 AM
spitz7985 spitz7985 is offline
Send a message via AIM to spitz7985
you can get 500hp out of a lighter engine. it would be more expensive but you would be quicker that way as long as you tune for a decent torque curve.
i'm thinking that for 500hp, you wouldn't need to upgrade internals on an RB.
Old 12-01-2003, 06:50 PM
klohiq's Avatar
klohiq klohiq is offline
^you failed to mention that most likely the engine's reliability will suffer due to increased stress on a smaller displacement engine designed to take less abuse. RB25 or 26 is good if you want lots of power...I don't need lots though...
just a pic i found of a p11 with skyline front and other stuff ViEt-G20 General 11 02-01-2002 07:40 PM
more carbon fiber hood and other stuff rants.. PrimeraGT General 3 07-24-2001 09:56 PM
JWT ECU and other stuff ??? Nismoboy1 Engine 5 06-07-2001 12:24 PM
