Old 12-01-2003, 05:10 AM
jeepse jeepse is offline
Question Loud Engine
Hi,
My 1997 Civic EX coupe's engine has sounded very loud (like a race car) the past month or so. The car seems slower and has gotten worse gas mileage. How do I get it back to sounding like normal? Thanks.
Old 12-02-2003, 01:39 AM
BullShifter's Avatar
Re: Loud Engine
Is there a hole in the exhaust?
When was the last time you did any maintenance?
Old 12-03-2003, 08:25 AM
IntegraBoy2003's Avatar
IntegraBoy2003 IntegraBoy2003 is offline
Re: Loud Engine
take it to the garage and have a mechinic look at it
http://www.retardsoftheday.cjb.net <<MY SITE, check it out, it is quite funny and Updated Every day
New York Yankees Join the asses, that rock the masses
David
Old 12-04-2003, 01:20 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: Re: Loud Engine
dude why even reply with that.. People use forums like these to gather help first and avoid going to the mechanic.
Jeepse, have somebody rev the engine while you look underneath the car and see if you can feel around for any gasses coming out (while the pipe's cold). If you think you feel something, put some soapy water over the suspected area and check for bubbles. If that's the case, go to a junkyard and buy a new exhaust for about $150 if you're okay with using a ratchet Check www.car-part.com and search for a stock exhaust in your area and it will give you a list of junkyards and prices. Hope this helps unlike dipshit's reply.
Old 12-04-2003, 01:51 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Re: Re: Loud Engine
lol, you should read all of his other replies
anyhow, check for holes in your exhaust pipes and exhaust manifold too. The factory exhaust manifold on my 4G civic had a good size crack in it and it was pretty loud.
Empty Pockets Racing Member #1
Old 12-10-2003, 03:53 PM
Thanks
jackasssi, Integraboy2003, Ricochet, and GScivic7--
Thanks for taking the time to reply and give good advice. After finals, I'm going to check about the exhaust problems you guys mentioned. Thanks again!
Old 12-10-2003, 05:28 PM
pmj92civic pmj92civic is offline
Re: Loud Engine
for an even quicker fix find some one who welds, or rent one and find the spot where its leaking and spot weld it
worked for me
Old 12-10-2003, 05:38 PM
mitchell1204 mitchell1204 is offline
Send a message via MSN to mitchell1204
Re: Loud Engine
is it loud under the hood? if yes, most likely its the exhaust manifold gasket or donut gasket(connects manifold to exhaust pipe) hold your hand near these areas and you can feel the airflow where the leak is. if its loud under the car, most likely you have a hole in the muffler.
Loud Engine noise amd25 SC/SL/SW 5 01-04-2011 06:46 AM
1977 impala loud engine knocking chevy_pimp2004 Impala | Impala SS 7 04-23-2005 01:47 PM
Engine Leaking-running loud--engine light not on leet2002K Wrangler 3 03-10-2005 02:01 PM
Engine Leaking-running loud--engine light not on leet2002K Wrangler 0 02-21-2005 12:00 AM
Protege 5 - loud engine? hard to start? music_fiend 323/Protegé/Familia/Etude/Allegro 3 07-31-2004 01:39 PM
