Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 12-01-2003, 02:34 AM
Greg<wVu> Greg<wVu> is offline
Garret Turbo w/ manifold
I plan on getting a Garrett T25 turbo w/ a turbo manifold that has a 35 mm wastegate flange. Im going to run the turbo around 7 or 8 psi with no intentions of upping the hp past 200. hopefully it will stay around 190 or so...will i need any other parts, other than the manifold and turbo installed so i wont have to worry about engine trouble? New to this so hopefully someone knows what they are doing.
Old 12-01-2003, 11:20 AM
tibby01 tibby01 is offline
you might wanna get some better pistons. the stock ones go at about 185ish. a better exhaust system is always a key part in a turbo system too. post your mods so far and that will help.
Old 12-01-2003, 11:25 AM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
new exhaust! thats a must
and a huge intercooler... you better have teh rigth place to put it....
and good luck with the turbo...
what does your turbo kit come with?
Old 12-01-2003, 11:51 AM
intercoolers are not always needed. they can actually hurt a system in some cases by reducing pressure. you must first determine the intake charge temp. and compare it with the ambient air temp. compare this with the an intercoolers efficiency, and you can figure out if an intercooler is even needed.
Old 12-01-2003, 10:30 PM
Thanks for the replies. I plan on getting a cold air intake, cat-back exhaust w/ the turbo and turbo manifold. I have a little cash laid aside for this project and wanted to get by with what i could. The pistons and intercooler are good ideas but i dont know if id have enough for them. I've looked around and am probably going to wait if they aren't necessary.
Old 12-02-2003, 01:11 PM
dont get a Cold air intake unless you plan on sellling it cause the turbo sucks air in from a totaly different place than a non boosted engine and the CAI will not fit right. your better off just sticking a cone filter on the throttle body for now and then sticking it on the turbo's compressor housing when you get that.
also, im guessing you have the a beta engine and not the v6 delta. with those relatively moddest hp goals, you might just wanna get a supercharger. it would probably be cheaper.
if you decide to go the turbo route, you might wanna look at this. i dont know how much your budget is... but this is a great price for the hp you get. click beta extreme turbo kit under turbo kits.
http://www.speed-factor.com/
the owner of this site is a moderator at www.hyundaiperformance.com and has a lot of experience. he knows what he is doing.
Old 12-09-2003, 11:14 AM
rxbandits rxbandits is offline
Re: Garret Turbo w/ manifold
what kind of driving are you going to be doing, daily driver, autocross, drag strip etc.
Old 12-17-2003, 08:42 PM
I dont plan on turnin my car into a racer; i just want some boost to go with the look. i have an '01 tibby and my dads been working on my body kit over winter (Veilside ) so im just tryin to get the power to match the look. I think ive decided to scrap the turbo and go with the CAI, 4-2-1 headers, and cat-back. hopefully that'll put me around 170 which is enough to live with . Just wanted to tell everyone thanks for the advice, especially tibby01, and ill definately check in the forums often for other ideas.
Old 12-18-2003, 12:47 AM
you wont get to 170 at the wheels maybe 160 crank, which is like 145ish at the wheels. hyundai's engine hp was slightly off, its only like 135 or so.
you could also get cams that would help out. the cams out of the 1.8L tiburon engine are supposed to work pretty good.
http://www.rdtiburon.com/index.php?n...iewtopic&t=556
other things like pulleys, a better clutch, high compression pistons...blah blah blah... there are tons of things you can get for the tibby engine without going boosted, and still have high hp.
also check the Group buy section of that forum, there is a GB on some pretty sweet headers for only 110 bux(i think).
check out some of these sites.
HYUNDAI RELATED SITES
some good forums are
www.newtiburon.com (2003+tibs
www.rdtiburon.com (97-01 tibs)
www.hyundaiperformance.com (largest hyundai site on net, they also have a very good store)
www.hyundaiaftermarket.com (very good archive files)
some stores stores
www.kspec.com
www.shop.hyundaiperformance.com
www.speedstate.com
www.importshark.com
www.speedmotion.com
www.sharkracing.com (some problems with customer service though)
and of course, ebay
this is my BIBLE... it is a complete online manual of every hyundai. www.hmaservice.com/webtech
kspec has some high compression pistons that would definately help. if you really want some help, go to www.hyundaiaftermarket.com and talk to Red. he has done tons of N/A mods(non boosted or nitrous) and has his tib running 14s now i think.
Old 12-19-2003, 10:35 AM
1QUICK2 1QUICK2 is offline
if you are turboing a N/A car.....ALWAYS intercool it. If you dont the intake temps will be VERY hot, probably hurting the HP. the hotter the air the less power you get. The only time you have to worry about intercooler pressure is if its too big for the turbo or too restrictive. The more mods you do...the more power, simple as that. The cams will help a lot, the more the intake valves open the more air your gonna get. If you only want that much boost...you need all the COOL air you can get, and a good exhaust to get the air out as well. also, get an S-AFC to controll fuel. get either a wideband O2 sensor or go to a dyno with one so you know your not gonna run lean with 7lbs of boost. You are prob gonna want a new clutch too. if you cant get the power to contact the wheels, its a waste of power.
93 MR2 Turbo-.20 over JE pistons,T3/04E 57 trim w/.63 AR,Intake,Greddy profect b spec 2 BC, APEX'I GT spec exhaust,Apex-i S-AFC, Turbo timer,550cc injectors,HKS trunk mount IC, B&M s/s,SPEC stg3 6puck clutch, TRD springs. Autometer gauges, PCP reverse indiglo gauges. P/P head,Intake, 17" SSR repl, Kaminari front lip and sides.338whp/272lbs tq at 18psi
FOR SALE! email: [email protected]
http://members.cardomain.com/1quick2
garret turbo kits unknownluder69 Forced Induction 8 02-08-2005 02:58 PM
T28 Garret Turbo 4-sale MR2GTR33 Classifieds 3 01-21-2004 01:20 AM
95 Gsx With A Stage 4 Garret Turbo!!!! 95GSX Off-Topic 10 10-15-2003 11:46 PM
