Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 11-30-2003, 05:49 PM
1llama 1llama is offline
1990 trofeo "hard start"
My 1990 trofeo has a hard start problem, seems to crank a long time and then stumbles into a run, also smells heavy of gas. seems to be when hot or cold but worse when warm. I did check the fuel pressure it seem good and maintains pressure when shut off. anybody have any ideas please?
Old 11-10-2004, 12:56 PM
c14Nitrogen c14Nitrogen is offline
Send a message via MSN to c14Nitrogen
Re: 1990 trofeo "hard start"
I have the exact same problem. The occurence of this problem with my car is really random. When I press the gas (normally), it's as if the engine hesitates for about 1 or 2 seconds, and then stumbles into a run.
I also have another problem with my 1990 Trofeo:
When i start the engine and leave it idle for about 2 or 3 minutes, the engine struggles and the odometer goes up and down. Its as if the engine is reving rapidly and shortly. And if I put it in drive, shortly after pressing on the gas, the car stalls... The transmission is automatic...why does it stall?
Old 11-10-2004, 11:56 PM
96aurora 96aurora is offline
Send a message via AIM to 96aurora
c14, did you recently disconnect the battery?
Old 11-11-2004, 09:29 AM
Nope. On the other hand, I did recently have it boosted when it died.
Old 11-28-2004, 03:13 PM
xbonz xbonz is offline
Re: Re: 1990 trofeo
what does disonnecting the battery have to do with anything. SERIOUSLY the battery died in the 86 toronada and that dont start ??
