Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-30-2003, 01:00 PM
john collins john collins is offline
Angry brake warning light stays on even though park brake is released in 1998 ranger
brake light brakr light brake light
Old 12-02-2003, 01:46 PM
bustedratchet bustedratchet is offline
Re: brake warning light stays on even though park brake is released in 1998 ranger
Check the brake fluid it might be low. If it is you can add some to see if it kills the light. If this is the case you may be due for brake pads.
Old 12-04-2003, 08:49 PM
freezin-mybunz-off freezin-mybunz-off is offline
you might also want to check the switch on the parking break. there is a little switch near the handle/pedal that makes the light come on when the parking break is applied. also the spring that pulls the handle/pedal back when the break is released might need tightened, thus not moving it far enough to switch the light off
