Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 11-30-2003, 04:58 AM
Bowza's Avatar
Bowza Bowza is offline
im new, i got a daytona cs
hey guys been reading over these forums the last....coupel days?..i've been interested cause me and my dad just baught a 1990 daytona cs with only 66k. i've read a bit of upgrades here and ther and what not..im thinking if i get upgrades i would start with a MP computer..any objections?.. or suggestions on what would be better for a 17 year old student to perform to increase hp/speed/power. And i no this question has been answered a bunch, but is ther a small list someone could put together of cheap upgrades doing differences in teh HP department.(dont go outa your way).
anyways i'll try to upload a pic and hopefully it aint too big..lookin forward to readin this forums more often..
Jay
Old 12-02-2003, 09:05 PM
PWMAN's Avatar
PWMAN PWMAN is offline
What engine does that have? Turbo?
If it's a 2.2 or 2.5 turbo, than go to www.FWDperformance.com and go to ECU calibrations. Their ECU's are better than Mopars. Then focus on your exhaust. If you have a 2.2L a 2.5'' exhaust will be enough. If you have a 2.5L go with the full 3'' turbo back exhaust. Just the exaust system will give you 15-20 HP after you've added the stage 1 calibration ECU. After those 2 mods, if you have the 2.5L, you should get an intercooler.
88' Dodge Shadow- 2.2L, 5 speed...a couple mods
[email protected] MPH
Old 12-04-2003, 10:20 PM
Bowza's Avatar
its a 2.5 turbo
so would i need to get the 3" downpipe and a 3" super turbo muffler? 1 or the other..both?..im almost clueless..
Old 12-04-2003, 10:28 PM
Bowza's Avatar
Re: im new, i got a daytona cs
another quick question being: my friend told me that before turning off a turbo'ed car..it should idle for a min or so..he says it ruins the turbo if it doesnt?..any truth to this?
Old 12-05-2003, 11:29 AM
PWMAN's Avatar
Depending on where you live, emissions may require you to have a cat converter. If not, use the test pipe. You need, downpipe, cat, cat-back pipes, and muffler from their site. For 2.5'' it all adds up to 300 dollars, for 3'' it adds up to 400 dollars.
Yes you need to let your car ''idle down'' after driving. The more aggresive your driving was the more you should let ot idle down. The housing of the turbo can get so hot it glows red, so shutting off the car right away it will cool down too quicky. Often causing the housing to crack, and burning up the bearings in the turbo.
Old 12-08-2003, 06:37 PM
Bazilisck311's Avatar
Bazilisck311 Bazilisck311 is offline
Send a message via Yahoo to Bazilisck311
never heard of a daytona cs. can you post a pic of your car? unless it was a typo and you meant to say es
Old 12-08-2003, 06:48 PM
nm.. just looked it up. Daytona C/S, i think all daytonas should have been equipped like this one, it was only $187 more..
good find bowza
Old 12-08-2003, 07:28 PM
86shelby_charger's Avatar
86shelby_charger 86shelby_charger is offline
Send a message via MSN to 86shelby_charger
Ah yes, the daytona cs, I have one of those, beautiful car. The CS stands for carol shelby, the god of affordable speed!! Cheap mods are, get a bleeder valve and put it in the vacumme line going to your wastegate! it's like $25 and it allows you to adjust your boost. I'll try to find a link later that shows you exactly how to do it, and it can give you anywhere from 5-100hp, depending on how you adjust it and how much risk your willing to take!! Raise the boost to 17psi and you should be safe, any higher and you risk blowing a headgasket! ( I have my shelby charger running at 22psi... I always have a spare headgasket on hand, but I haven't had to change it yet...knock on wood!!)
goto www.thedodgegarage.com Theres a ton of stuff there that you can do to up your hp a bit! Have fun!!
If you can't hear it coming....Why bother!!!
Old 12-11-2003, 01:08 AM
CUTTER0 CUTTER0 is offline
Send a message via AIM to CUTTER0
1st thing is 1st, make sure you have a boost guage so you know how many reliable psi you can run. Also look into a upgraded turbo, fuel, ignition, exhaust, intake. Whatever fits your budget. Also invest in a turbo timer. It lets the car idle for a few minutes to let the turbo cool down. Since turbos are oil cooled if you shut the car off all that hot oil sets in the turbo and can ruin the seals. Letting the car run for a few minutes helps cool the oil before shutting it off so it saves your turbo. I #1 of 7704 made and im parting it out. If anyone needs parts let me know. [email protected] Or see my post.
Old 12-11-2003, 01:59 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I would go with that PWMAN has suggested except I wouldn't bother with a muffler, you don't really need one. Also make all the pipe is mandrel bent. As for the turbo timer, why waste money on something you can do for free?
Old 12-11-2003, 02:22 PM
PWMAN's Avatar
I agree, those are only for lazy people. Save that 100+ dollars, and buy other performance stuff.
Yeah you don't really need the muffler, I am currently running straight pipe with a HFC. Not loud at all. And it's a good aggressive tone too.
The very first thing you should do is buy yourself a bottle of fuel injector cleaner, make sure that no cylinders are going to be running lean when you go to up the boost.
Here's a cheap way to get 5-10 HP-Buy a universal KN filter, go to home depot and buy some kind of ducting that is easily flexable and route it somewhere it will pick up cold air. The filter will cost 35 dollars from FWDperformance, and the pipe probably 10-15 dollars.
So here's the recipe- do the intake and exhaust mods first. Then get the FWDperformance stage 1 calibration. Then look at forms of intercooling, that will give good gains if you get a front mount one. But just with the intake/exhaust/ECU calibration you should have 50 HP over stock. Then add the IC, and get anywhere from 15-50 more HP.
Old 12-11-2003, 03:42 PM
Lazy people? So if your in a hurry and late for work/school/appointment or whatever and you beat the shit out of your car to get there.... Do you think you want to wait another 3 minutes just sitting in your car? no! Im sure you will turn it right off saying "Oh one time wont matter" Beileve me I have had 4 turbo cars, and only 2 had turbo timers. The turbos that didnt have turbo timers went under 100k miles. The ones that did..... Well my MR2 turbo has 130k miles stock turbo, and my supra has 140k miles stock turbo. You can find them used for under $100. One of mine I picked up for $60. Better then spending a few hundred $$$ for a new/used turbo, especially if your turbo is upgraded or bigger. Dont want to waste $1000 now do we?
Old 12-11-2003, 04:10 PM
Polygon's Avatar
The Red Baron
Re: Re: im new, i got a daytona cs
If the turbo goes it was your own fault. The problem with turbo timers are the fact that if you have a car alarm you have to wait anyway because you can't activate the alarm while the car is still running. The other thing is that driving fast doesn't use the turbo, accelerating fast does. When you're at speed the turbo isn't boosting. My LeBaron GTC had 152,000 miles on it with the original turbo boosting 13 PSI. It would have lasted longer had it not been totaled in a car accident. The point is that I never used a turbo timer. If I had been really rough on the car I would drive around normally for a few min then pull in and let the car idle for about thirty seconds. If I had just driven normally I just let it idle for about 30 seconds before shutting it off. I also don't care much for devices that splice into the ignition. You’re only looking for problems. I am sorry but it is just my opinion that turbo timers are a waste of money. If you’re running late, big deal, if you can be fifteen minutes late you can be fifteen minutes early. I just feel that I could think of a lot of things that would be better to spend one hundred bucks on.
Old 12-11-2003, 04:40 PM
PWMAN's Avatar
Ahh polygon you beat me to it. I was going to say the same thing, that not every time you drive you have to let it idle for 5 minutes. In fact, I don't think you EVER need to idle for 5 minutes after driving. That is a long freakin time, the car almost warms up in 5 minutes. Most of the time I only do about 30 seconds like Polygon said, because I just puddle jump in my Daytona mostly. The longest I've ever idled down was probably about 3 minutes, only because I specifically hammered the car on that particular drive. 3 minutes is plenty no matter how you drive, 30 seconds should be a minimum though.
Old 12-11-2003, 10:14 PM
Brand new turbo timer buy it now price of $49.99 There are some under that. Even though you may not use your turbo under loan, it is still oil cooled.
I got beat by a Dodge Daytona Dr. Love Street Racing 18 02-18-2014 11:21 AM
(eBook) Buying New and Used Car Tips schumi_reloaded Car Buying Q&A 2 06-05-2009 11:18 AM
new aftermarket parts for sale tommy67 Parts for Sale 1 04-24-2009 01:34 PM
New Feature '97ventureowner Cars/Parts for Sale/Exchange 0 02-19-2009 10:21 PM
