Old 11-29-2003, 09:32 PM
buffer41 buffer41 is offline
Read out say's low tire pressure
My tire got a slow leak and the read out said check tires low pressure. Since I have got it fixed and put 33 pps in each tire and it stills says low pressure. how can I fix the problem. Please resolve any one.
Old 11-30-2003, 05:58 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Read out say's low tire pressure
You need to rest the system!
On the left sidew of your instrument cluster you have some buttons. Press the gauges button till you get the LOW TIRE readout now press reset button the bottom button and hoid for 5 seconds till the system resets.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 02-02-2004, 08:49 PM
bill burgess bill burgess is offline
have 99 park ave w/3.8 , and have same problem with low tire pressure readout in the dic. please tell me precicely which button/s to push to reset the system. i have tried holding the reset and the eng/met buttons simultaneously for 5 seconds and the system seems to reset but the readout comes back the same when the engine is started again. please help.
Old 02-05-2004, 07:49 PM
LoneWolf3's Avatar
LoneWolf3 LoneWolf3 is offline
Low Pressure
Bill....You have those buttons as Flatrater said, you have to press Gauges button until you see the tire pressure one, my suggestion, fill tires to pressure you want, then press and hold button until you see words "RESET" then if your tires go down 12 PSI below what you filled up to example 35 psi , you have a leak goes below 23 psi you'll get message, have to fillem up reset again.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 09:39 PM
