Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 11-29-2003, 05:02 PM
bigbob bigbob is offline
got boost?
hey fellas, how much boost can the a stock wrx engein take?
Old 11-30-2003, 10:58 PM
MB38's Avatar
MB38 MB38 is offline
Send a message via AIM to MB38
Re: got boost?
Are you talking how much it can take regularly, or how much it can take without exploding after one run?
Old 12-01-2003, 01:07 AM
Re: got boost?
lets go wtih both
Old 12-03-2003, 04:14 PM
Stytch Stytch is offline
Send a message via MSN to Stytch Send a message via Yahoo to Stytch
I've heard 18psi is absolute maximum boost without causing damage. At 17psi I get a regular fuel cut, so I've set 16.5psi as my personal maximum boost.
I also still have the stock boost gauge and have heard it is not very accurate. Can anyone address this? I created this graphic to help me figure where on my gauge 16.5psi is:
Old 12-03-2003, 05:17 PM
ragnarok720 ragnarok720 is offline
The engine can handle a significant amount, not sure of the exact rating. The stock turbo however will explode at 18 psi with extended use or even 1 racing run. Larger turbo will make it so you can run a higher boost but you'll need fuel management etc at which you can change fuel cut off's i believe with say the Turboxs Utec ECU.
Old 12-03-2003, 05:18 PM
FortyTwo FortyTwo is offline
Stytch is correct, 16.5 psi seems to be the maximum reliable boost.
Old 12-04-2003, 04:34 PM
Re: got boost?
can u set any ecu so u have two maps and u can change between them and go form 16 or so psi to like 10 psi so for trips and normal driving ur under no stress?
Old 12-04-2003, 04:38 PM
MB38's Avatar
Re: Re: got boost?
Bob, it'd be best to do that from a good ol' EBC like a PRofec B Spec II. Most ECUs have you manually change the boost setting closed-loop (so the ECU has no communication with the boost level), so using an EBC with two settings wouldn't effect it.
Now, I'm curious about the turbo exploding at 18psi. A [VERY STUPID] friend of mine did a single 0-100 run at 22psi on the stock turbo, intake and exhaust. While there was detonation galore, the car held together (and absolutely dominated the 550hp M5 it was racing). Basically, DON'T DO THIS, but it doesn't literally explode at 18psi.
Old 12-04-2003, 05:20 PM
He got pretty lucky then. Turbo Magazine i believe was messing with a wrx and ran the boost at 18 psi for a single 1/4 mile run the the turbo went bye bye as well as #3 cylinder.
Old 12-06-2003, 03:12 PM
Re: got boost?
mb38 im no ur ecu doesnt mess with boost but i am jsut asking if u can have two different maps on it cuz if u have it tuned for 16psi and then go to 10 on ur boost controler on the same fule map its not gunna run as well
Old 12-06-2003, 05:20 PM
MB38's Avatar
Re: got boost?
Of course you could.
Old 12-07-2003, 04:18 AM
Heeven Heeven is offline
Re: got boost?
Hello I am new to this forum I am running a Turbo XS Utec stage 4 with Perrin fuel rails and many more mods. I have been running 1.3 bar (18.85psi)for about 20,000 miles, I have hit up to 1.5 bar(21.75psi) due to boost creep it scared the heck out of me but it did not blow up, but it pulled like a son of a @#$%*!! My boost cut is set at 22 psi on the utec. My point is with proper tuning you can hold 18 to 19 psi on stock internals but do not expect to get over 100,000 miles on it I am at 46,000 miles and it still fells strong but I will not be suprised when it does finaly blow. When it does then I will build a engine that will hold 21 psi all day because I am now a boost fiend!!!!!!!!!!!
Heeven
Old 12-07-2003, 08:29 AM
Alldar's Avatar
Alldar Alldar is offline
Re: got boost?
driving down the road and BOOM
Old 12-07-2003, 08:35 PM
Re: Re: got boost?
Yes that is what it will sound like well more like BOOOOMMMM!!!!!!!!!! Then CRUNCH then silence.
Old 12-08-2003, 12:34 AM
drifter350 drifter350 is offline
500hp WRX's mates!
http://www.wrxfanatics.com/videos/apc_wrx.wmv
https://webspace.utexas.edu/kiliansw/WRX%20Rev.MPG
supercars.net/Board
Got Boost? Want some? CougarSVT Contour 20 01-28-2010 03:42 PM
New pics!!! GOT BOOST??? (Many images) wkma7six WIP - Street 53 11-29-2003 03:31 PM
Got Boost? Want some? CougarSVT Cougar 10 05-27-2003 04:29 PM
Got Boost? luckym85 3000GT/Stealth 2 01-13-2003 10:49 PM
