Old 11-29-2003, 03:50 PM
caminsc5 caminsc5 is offline
Send a message via AIM to caminsc5 Send a message via Yahoo to caminsc5
Question cold start?
i have a 89 crx si w/ dohc zc swap. it has just started getting cold here, and i have noticed it takes a few times of trying before my car will crank. once its cranked the idle bounces up and down (from 100-500) for a cpl minutes before it finally warms up, then it will stay idle at about 2000. why does it idle so high and is there anything i can get/or doto help my car crank easier? thanks.
Old 11-29-2003, 04:11 PM
BullShifter's Avatar
Re: cold start?
By not cranking, I assume you mean NOTHING happens. Crank no start is when the engine tries to start. If nothing happens(no crank) I would check/test battery/connections, starter/connections, ingition switch. For the idle problem I would consult a repair manual - Idle Control System.
http://www.binghamtonlife.com/manual...s/91-11-71.jpg
http://www.binghamtonlife.com/manual...s/91-11-75.jpg
http://www.binghamtonlife.com/manual..._emissions.htm
Old 11-29-2003, 04:40 PM
Re: cold start?
ok wel when i got to crank it (when its cold) it will turn over (lights and everything come on) but just not start up. or it will start up (only for a second) and turn back off. after this a cpl times, it will start
97 S10 Blazer Hard Cold Start Problem Pilot423 Problem Diagnosis 1 10-14-2009 02:01 PM
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
hard to start when cold 88alldae Caprice 2 08-03-2009 09:16 PM
96 Grand Am SE 2.4L Hard Starting Period Gman2007 Grand AM 2 04-13-2009 05:44 PM
Cold starting in general and runs rough when cold starting searcherrr Windstar 11 12-10-2006 11:42 PM
