Old 11-29-2003, 03:39 PM
JimCRX's Avatar
JimCRX JimCRX is offline
Ignition Output Signal, ECU throwin code 15
My 91 crx si has been acting up lately. If I let it sit for awhile it'll be hard to start up. Sometimes it just constantly dies soon as it starts up and the check engine light comes on every now and then and when i start driving it stutters and the rpms bounce around. I checked my ECU and it has been throwin the Ignition Output Signal, Code 15. I checked the battery and alternator. They seem fine. It's got new spark plugs, wires, cap, rotor. Anyone know anything about this. Thanks, Jim.
Old 11-29-2003, 03:43 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
Re: Ignition Output Signal, ECU throwin code 15
Check to make sure that the rotor is on tight. The set screw is known to come loose.
Old 11-29-2003, 04:31 PM
BullShifter's Avatar
http://www.binghamtonlife.com/manual...s/91-11-62.jpg
http://www.binghamtonlife.com/manual...s/91-11-63.jpg
http://www.binghamtonlife.com/manual...s/91-23-63.jpg
http://www.binghamtonlife.com/manual...s/91-23-56.jpg
Old 11-29-2003, 06:17 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
I was throwin this code recently. Do be sure that that DAMN SCREW is on tight on the rotor. Pull your distributor cap, and check your connections to the ignitor. That will cause it to throw cel 15 if one's loose. Also, go to your ecu, and verify that the wire goin to pin C05 is intact (mine was severed).
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Ignition Output Signal Hog Caller Let's get Technical! 19 11-29-2008 12:59 PM
ecu code 15 ignition output signal xsmilk Integra 0 08-25-2006 12:11 AM
ignition output signal G3_preludeSI Prelude 1 10-29-2004 11:50 AM
ECU Code 15.....Ignition output signal gmoorhouse Integra 0 08-12-2004 07:23 AM
