Old 11-29-2003, 02:41 PM
mstarcom mstarcom is offline
Unhappy schizophrenic automatic transmission
I just purchased a 93 Impreza with 175,000 mostly freeway miles.
Usually the automatic transmission shifts smoothly. However,
sometimes when under moderate acceleration the transmission cant seem
to make up its mind what gear it wants to be in. This happens mostly
with the 3rd to 4th shift, but has also happened a couple times in
the 1st to 2nd shift. As soon as the shift to the next gear takes
place, it will immediately shift back down again. When on the freeway
this can continue back and forth till I manually shift to 3rd or give
it much more gas in which case it will stay in 3rd, or back way off ,
in which case it will stay in 4th. Is the shifting controlled by a
computer chip? Is this something an adjustment can fix? Thanks for
your input.
Old 11-29-2003, 04:14 PM
bm2boats's Avatar
bm2boats bm2boats is offline
First, try the Cheap way. Change your transmission filter and then, go to a service Center and get your transmission fluid flushed. It is a machine that hooks up to your transmission and pushes out the old fluild and replaces it with flesh clean fluid. Filter will cost about $10.00 to $30.00 and the flush will cost about $69.00 to $120.00.
Try it, it MAY work.
96 Dodge Van 3500 Automatic Transmission Failure vince2010 Ram Van 7 01-14-2013 03:12 AM
01 Civic Automatic Transmission Shifts like...? Shrewz92 '01-'05 Civic 9 08-15-2010 02:45 PM
trooper 1993 3,2 Dohc , automatic transmission change windfast Trooper | SLX | Bighorn | Wizard 0 04-26-2010 12:21 PM
Automatic Transmission not so automatic keyplayah71 Park Avenue 2 10-19-2003 07:40 PM
