Old 11-29-2003, 10:57 AM
98GS-T 98GS-T is offline
Send a message via AIM to 98GS-T
Question Stock turbo
Alright is there any way to get more power out of the stock turbo? I know that mitsubishi problably has the turbo turned down on it and i want to have it as high as it goes.Thanks in advance!
Old 11-29-2003, 02:52 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
buy a boost gauge, buy boost controller, turn the boost up. in that order. can turn it up to 15-16psi
-Agim
Old 11-29-2003, 03:26 PM
kjewer1 kjewer1 is offline
AF - Advisor
The stock 2g boost is 14-15 pounds. You can only go to about 16 on pump gas with that shyte turbo. Mitus pretty much maxed it out for us Do all of the proper supporting mods first instead of going for more boost. Boost is only a small part of the equation. Once you have all the appropriate stuff upgraded, you can go a bigger turbo that will be able to run more boost.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-29-2003, 06:55 PM
thanks for the help guys! So i'm guessing start with a CAI followed by exhaust. Now for my exhaust I was kinda leaning towards how the eclipse in the first F&F was nothing louder i liked the way it sounded. Any help on any of this would be appriciated! I know you guys have been through this a number of times with the other newbies so i'll try to go back through the post on most things!
Old 11-29-2003, 07:27 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Stock turbo
the exhaust in f&f was a simuated sound but i recomend that apex-i n1 if you want a name brad exhaust but to save money go to a good exhaut shop and let them bend you a 3' exhaust and just get the muffler that you want and you will be ok!
1
Shift_BOOST
97 s14
Old 11-29-2003, 07:40 PM
the Apexi N1 muffler runs about 30 bucks on ebay. should i get that then have the cats cut out and run straight pipes from the headers? How much would this cost (average) at a muffler shop?
Old 11-29-2003, 07:42 PM
would 3" be to big for the turbo on my pipes. what would be a good size to run?
Old 11-29-2003, 08:09 PM
Re: Stock turbo
..................3"
-Agim
Old 11-29-2003, 09:31 PM
Re: Stock turbo
i could problabaly get this and the boost gauge or controller done at x-mas. So i'm wanting to know which brand to go for greedy hks or something else?
Old 11-29-2003, 09:44 PM
http://www.dsmtuners.com/tuning-guide/2gturbo/
-Agim
Old 11-29-2003, 10:05 PM
sweet! 18 steps to get your eclipse up to 400hp!! is that 400 FWHP or at the crank?
FourG63 97GST: what's been your best upgrade that you have done that really made a difference?
Old 11-29-2003, 10:07 PM
do they make superchargers for our cars or just turbos cause superchargers do run cooler than turbos right?? i might be wrong so let me know
Old 11-29-2003, 11:35 PM
TurbosR4me's Avatar
TurbosR4me TurbosR4me is offline
Re: Stock turbo
All of those sites rate in wheel HP. The only other measurement it could be rated in would be estimated HP, and that means nothing.
Old 11-30-2003, 01:56 AM
AF - Advisor
The exhaust shop setup is good for jsut a cat back. Unfortunately for us, most of the power to be gained is also in the downpipe and cat. Get a full turbo back exhaust from sites like
www.bushurracing.com (my favorite)
www.roadraceengineering (great DPs, but I dont care for the name brand catbacks)
Damn. Its late and I cant think of my usual list. But thats what to look for. DSM SPECIFIC shops make the best exhaust for cheap money. No brand name to support. BR exhaust are running 8s if that means anything. Go for the 3" now, or you'll end up buying two full exhausts like me LAst time I asked my exhaust shop what they would charge for a full setup and its still a little more than a BR turboback. If you do go this route, say you buy the RRE DP, and get the catback made, use the Dynomax Ultraflow 3" in "Welded" (cheaper) or "Stainless" (more of course). Its been tested by a local guy to flow better than a 3" pipe. Why? It has a 4" inner diameter. BR uses these on thier exhausts, so it sounds just like a BR exhaust. This is what I did. I bought the RRE "long" DP, and made my own catback based on the Ultraflow Welded.
Forget the supercharger idea, turbos are superior in our applications. There is a reason DSMs are running 8s and 7s on turbos.
Also keep in mind that with a 3" exhaust you have to deal with boost creep. While this may not appear on the stock T25 turbo, when you upgrade you will have to take this into consideration. Boost creep is bad. Search on here and on the tooners site shown to you above. Search with my username if that helps. I've posted EXTENSIVELY on the topic on tuners and talk. Same name as here, with no spaces.
Also, my car makes 400 HP at the wheels on pump gas, so you can look at my mod list on www.posracing.net to get an idea of what I have put into the car. The built motor isnt required, but I feel better knowing its there
Kevin Jewer
Old 11-30-2003, 02:16 AM
mr2mitch mr2mitch is offline
Send a message via AIM to mr2mitch
98gs-t you came to the right place for info my friend everything 95gsxracer says take to heart he knows what he talking about he lead me in the right direction everytime. This goes to the Fast and furious deal that movie was a great car movie and thats it hardly anything in that movie was up to par about tunning and how it really is they just did a lot of name dropping for diffrent performance companys. like everyone said get a downpipe 3inch,after the downpipe comes the cat in the stream you can either get a racing cat or if your aloud you can get a test pipe which is straight thru,after that get 3inch pipe all the way back and a free flowing muffler make sure it has a 3inch in let and at least a 3inch out let. like they said get a boost guage becuase the stock one isnt accurate at all it dosent run on vacume. remember now you dealing with a turbo car now not a naturally aspirated car you dont have a header anymore and you dont have an intake par say all your air supply comes from the turbo so you dont buy a normal CAI your air is cooled by an intercooler. the best thing to do is to just research on your own and ask alot of ?s were here to help.take it easy
mitch
Putting stock turbo into non-turbo Z? ShinRekka 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 02-03-2003 05:28 PM
Stock Turbo specs Gonthrax Performance 0 04-28-2002 03:05 PM
nissan stock turbo? andyfong Engine 7 12-27-2001 09:35 AM
R33 GTR Stock Turbo Good or Bad 4 2.0ltr cynider Performance 0 12-04-2001 12:28 AM
