Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 11-29-2003, 10:33 AM
Kirknrenae Kirknrenae is offline
Send a message via AIM to Kirknrenae
Unhappy Keyless Entry!
I'm in dire need or Instructions on how to Program the Keyless Entry. My manual doesn't explain it to me just says how to replace battery. I recently bought a new Keyless entry off Ebay and can't get it prgrammed any advice without paying for it would be GREAT! Thanks, Kirk
Old 12-08-2003, 08:54 PM
lilcougar99 lilcougar99 is offline
Send a message via ICQ to lilcougar99 Send a message via AIM to lilcougar99 Send a message via Yahoo to lilcougar99
I bought my motes of ebay as well an I have programming instruction but the thing is they dont work either... have fun trying to get an answer out of anyone that reads your post I still have not got any help on my question...
Old 01-16-2004, 04:10 AM
blacksheep883 blacksheep883 is offline
Send a message via Yahoo to blacksheep883
Re: Keyless Entry!
Consult your Ford, Lincoln, Mercury dealership service department. I'm sure they can help. They shouldn't charge you too much, if they charge you at all.
Old 01-23-2004, 09:22 AM
Martin Coffman Martin Coffman is offline
I bought a keyless entry and checked all the websites and advice and they were all wrong. We called the Lincoln/Mercury dealer and they would program it for $5. Seemed fair.
He had to short some pins on the unit in the trunk to program it and the unit wasn't there. Turns out, my Cougar was not equipped for keyless entry!!I should have checked closer before buying the remotes on ebay. Anybody need a mote for a 96? I don't know the entire procedure for programming but it involves doing something to the receiving unit in the trunk.
Old 01-24-2004, 09:27 PM
bjw1960 bjw1960 is offline
Send a message via Yahoo to bjw1960
Thumbs up remote keyless entry
I found the way to program remotes in my Ford Taurus manual. This may or may not work for you. Have remote ready. Put key in ignition switch, turn from on to off {without starting vehicle} quickly 8 times. After the 8th time, the doors will lock. QUICKLY push one of the buttons on the remote. Repeat for any other remote. GOOD LUCK. Bill
Old 04-18-2004, 10:17 PM
thepartsyouneed's Avatar
thepartsyouneed thepartsyouneed is offline
Banned
Re: Keyless Entry!
These instructions will work on Thunderbird / Cougar models, 93 - 97:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in LR quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
I have these remotes available in my Ebay store.
Old 04-15-2005, 02:05 AM
minejmj minejmj is offline
Re: Re: Keyless Entry!
what do your mean by Jump pins in the programming connector in the LR quarter panel? I just baught a new remote for my cougar and I need help!
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
