Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-29-2003, 09:46 AM
PistonSlap PistonSlap is offline
Engine swap
I have a 94 with real real real bad piston slap. The car has over 200K but I'm not sure about this engine, I bought it used. Here are the paticulars about this car VIN has a 4 in the 6th digit, Engine code is B18B1 #1353263 and it is an automatic 4spd code SP7A-2004390. I'm looking to do an engine swap:
1. Will all B18B1 engines fit?
2. Any mounting problems between auto trannys and manual?
*new*
3. Don't want to go Vtec.
Thanks
Old 11-29-2003, 09:49 AM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Engine swap
All B series motors will fit with minor wiring if you go Vtec. Not sure about the auto to manual though.
Check out my car here My 91 Hatch
Old 11-29-2003, 09:57 AM
Engine swap
Thanks for the quick reply, I should have said this in my orginal posting I'm not going Vtec.
what kind of wiring mods?
Old 11-29-2003, 08:34 PM
Re: Engine swap
You don't have to wire anything if your not going Vtec. Its a direct swap just go for it.
Old 11-29-2003, 09:02 PM
Re: Engine swap
Sorry about that, as soon as I posted my reply I re-read your message and understood that you meant the change is needed to go Vtec.
My current tranny is an automatic. All I want to do is an engine swap to keep the car running (least possible cost) that is why I asked about tranny mounts. Are there engine mounting differences (bolt patterns) for manual trannys and auto trannys?
Thanks for your help I really appreciate it.
Old 12-01-2003, 09:45 PM
DC87teg DC87teg is offline
they'll all fit
all b-series motors will fit with some minor vtec subharness stuff.......as for the tranny,the hydraulic clutch parts and the master and slave cylinder need to be installed as well as your pedal assemblies on the interior.....
Old 12-01-2003, 09:56 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: they'll all fit
You should read the posts before you post a reply, you in no way answered the question at hand.
Moving on to the topic at hand no the bolt paterns are not different, they will all be the same on the motor, the only different mounts are the ones that attach to the tranny, which won't matter in your case. You will be fine just get a B18B1 and it will be a simple swap, the only thing you might run into is if you get a motor from a 96+ that is OBDII if you do then all you need to do is swap the intake manifold for your old one and that is it, or you can leave the manifold that comes with the car on there and just not plug in the extra sensor that is on to of the intake manifold. Good luck let us know if you need more help.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
