Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 11-29-2003, 07:22 AM
dog1 dog1 is offline
Angry Passat has anchor attached
1999 Passat 1.8T automatic just will not run the way it use too. I believe the tension arm for the cam chain is noise and the gaskit should be replaced, but even for 120,000+ I should have a lot more power. I noticed that the tranny will drop two gears were it need to drop only one before. I've replaced my plugs, fuel filter, and air filter. Nothing. I asked my mech. if the catilitic converter might be clogged. He stated that it didn't appear so due to the lack of noise. I asked about the turbo. He states again, that it sounded fine.
I normally use high octain gas 92+
I noticed that I getting oil on the sheath under the engine.
Old 12-05-2003, 10:16 PM
boschmann boschmann is offline
Re: Passat has anchor attached
I'd find someone who can check the cat by checking the exhaust backpressure (easiest to do through the oxygen sensor port) since they can get clogged w/o breaking up & rattling. A clogged cat usually would have made the exhaust sound different (especially at high RPM's), but it could have changed slowly & you don't notice it. It could also have a turbo problem even if it sounds fine. Verify the oil leak isn't coming from there - also look for it pumping oil into the air intake system.
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
Post Attachments now available igor@af AF News 5 12-20-2009 08:40 AM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
Passat Has Become a Bucking Bronco bluejudy '93 - '96 2 02-21-2006 09:07 PM
