| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Someone please explain downshifting for acceleration to me!!
I understand that in the lower gears you generally have more power, but I just not visualizing why you would downshift to get acceleration. Can anyone explain with couple of examples.
Re: Someone please explain downshifting for acceleration to me!!
It's like when you downshift on a hill, you don't downshift to slowdown, you downshift to maintain speed. You select a lower gear to let the engine rev higher, closer to it's power peak than it was in the higher gear. Of course this is only workable when the car is revving pretty low in a higher gear; like 40mph in 4th, come to a hill, shift to 3rd and continue going 40mph. Or in the case of accelerating, shift to 3rd and accelerate to 50mph before shifting back into 4th - of course where you shift is going to change from car to car.
![]() Support America's dependence on foreign oil - drive an SUV! "At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald. If you find my signature offensive - feel free to get a sense of humor. |
Because you get more torque. F = ma.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable. |
Thanks for the replies, but if you rev the engine over the given rpm doesn't that "burn the clutch up"
It will only burn the clutch up if the clutch is slipping. A properly setup clutch shouldn't slip if you don't have your foot on the clutch pedal.
You have to remember that gear ratios multiply torque. So a lower gear will give you more torque at the wheels, but at the expense of wheel speed. This is why lower gears pull harder than higher gears. |
The more times an engine can rotate, the more horsepower it can make, generally speaking. Therefore, you want to select a lower gear to make the engine rotate more, creating more revolutions a minute accomplishing more work in the given time. This is only a general rule; the important thing to follow in any car is the powerband--the rev range that produces the most power. But, generally speaking, you will make more power at 4000rpm than 2500. As for your clutch, unless it is extremely worn out or improperly installed, it won't burn up, spin or otherwise self destruct unless you ride it (keep your foot halfway depressed on the pedal, allowing the clutch to spin to control accleration).
Jon
2000 Mustang GT [email protected] Exhaust 2000 Celica GTS 6-speed A very pathetic 16.5@88mph (could not shift into 2nd or 3rd) Intake 1994 Integra LS I/H/E 1990 Integra RS 16.6@85mph Intake |
but what about in automatics?-is this any different? b/c i've been messing around w/ the shifting N-D-3-2-1....another recent post in here spurred my curiosity. anyway, if i'm in drive and i shift to 3rd, my cars slows down a little, then if i shift down to 2nd slows down even more, and 1st it actually jolts to about 10-15 mph. so apparently this is not supposed to happen, or could it be different in auto's than man? when i downshift like that, i can hear the engine 'de'-reving; idk if that's what it's actually doing, and idk if it's good for the tranny.
krebs, are you named after the ATP producing cycle of the same name?
Jon
haha, wow. just a little off topic but no, i'm not named after the Krebs Cycle-though many retarded ppl at my school acredit me for the cycle....
Just checking
well, anyone have an answer?
well if you did that in a standard it would do the same thing if you didnt give it gas. it jolts to 10-15 mph because first gear is a lower for starting off
Re: Re: Someone please explain downshifting for acceleration to me!!
Jon
well hey, i figured it wasn't good, so i don't do it...but thanks for the reply. krebs-cycle, haha
the only time I really use the to control/slow down the acceleration is when I am in reverse, because it is easier that way? Could this cause problems?
