Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-28-2003, 10:10 PM
mattbrye mattbrye is offline
Turbo Detonation
WHat is meant by detonation..what causes it and what is it??How do u prevent it..sry guys..basic questions i guess but im still learning..all help is appreciated
Old 11-29-2003, 09:20 AM
TEAM KLR's Avatar
TEAM KLR TEAM KLR is offline
Send a message via AIM to TEAM KLR
Re: Turbo Detonation
TUNING is the soloution to everything. it is when the fuel and air in the engine ignites before it is supposed to. VERY BAD.
Old 11-29-2003, 07:46 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
hen tuning cars the proper timing for the fuel and air and the detonation is critical. thats why alot of people spend lots of $ into tuning their cars.
1
Shift_BOOST
97 s14
Old 11-29-2003, 11:38 PM
SOHCD16y8 SOHCD16y8 is offline
detonation is when the air fuel mixture ignites before the spark, this is often cause by hot spots on the pistons and too much cylinder pressure, this can also cause misfires, the easiest way to prevent this is to retard the ignition a few degrees, this will solve most problems.
Old 11-30-2003, 12:26 AM
how do u retard the ingition..does the HONDATA do all that for u?
Old 11-30-2003, 01:01 PM
Rgacke's Avatar
Rgacke Rgacke is offline
You use a timing gun/light and use a step colder spark plugs. Also make sure your ignition/fuel system is healthy.
"shut the door Joshua, and let death pass by..."
Old 11-30-2003, 08:24 PM
You can use a timing gun or if you are planning on buying an ignition system buy an MSD digital ignition and you can retard or advance by the turn of a knob
Old 11-30-2003, 08:34 PM
edman24 edman24 is offline
Send a message via AIM to edman24
Re: Re: Turbo Detonation
what detonation is has been covered but to prevent it there are a number of ways.
1.lower compression-when boosting if the compression is too high combined with the boost will produce detonation
2.run rich-running slightly rich will prevent detonation to an extent
3.provide enough fuel-even high compression motors can be boosted to hell but they need enough fuel and ignition to compensate. tuning, tuning, tuning!
4.retarding ignition-although this works, it cuts your power considerably. not the best way to do it.
I feel bad for those who pay twice as much as i did for my car and still lose to me. The sorrow in their face is enough to bring me to tears.
Old 12-02-2003, 08:18 AM
TEAM KLR's Avatar
we run 16 deg btdc on our ls with 9.5 comp, 15psi, safc 310 cc injectors, to4-e, and no detonation, it is all in the tuning, when you retard the timing you loose power, if the fuel settings are correct you will not have to worry about the timing untill you cross over the 300hp mark, we are making just over 300 atw with that set up, that is our street car.
Old 12-03-2003, 12:16 AM
cuba3377's Avatar
cuba3377 cuba3377 is offline
Mattbrye , a very important factor in detonation that is sometimes overlooked, is the fuel quality.
Higher octane rating = less possiblity of detonatation.
Lower octane rating = more possiblity of detonation.
Turbo vehicles tend to be picky on octane.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
