Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 11-28-2003, 07:29 PM
enimox7's Avatar
enimox7 enimox7 is offline
flooding in fc
A recurring problem I'm having is that after driving my fc and giving her more gas than is some times necessary, once i turn her off and let her sit for a while, i have trouble starting up again. It probably has something to do with the 40 degree weather i'm in now, but i also heard fcs are easy to flood. I have an EFI though. Has anyone else ever had this problem. One of the guys at circuit city that helped install my deck heard my car when i had starting problems and suggested that it could be the fuel pump. Any ideas or suggestions?
Old 11-28-2003, 09:45 PM
Entreri33's Avatar
Entreri33 Entreri33 is offline
Send a message via ICQ to Entreri33
Ok this is actually a common issue in the FC. We all realize that unlike a pist-on engine a flooded FC will not eventually unflood itself. You need to do the pulling fuses trick occasionally to get it running again. This problem is often compounded by making frequent short trips where the engine DOES NOT come up to full operating temp. Cooler 160 deg thremostats aggrivate this problem. When I had my 87 sport (non turbo) I always let it sit and idle a couple minutes after making any trip (acting like I had a turbo timer working on it. It solved 99% of my flooding issues.
Had 2 cars totalled in 2 years.... searching for a new toy. Maybe another RX7(w/20b) or a 280Z(w/rb26dett)
I had...
87 RX7 sport (drove it for years)
01 Firebird
Need a new project car.
the 5th column will be the death of the american dream.
Old 11-30-2003, 12:19 PM
Steel's Avatar
Steel Steel is offline
Re: flooding in fc
Yeah. You dont even have to pull the EFI fuse if you've got an S4. All you have to do is put the pedal to the floor when you start it, that automatically cuts off fuel, so you can crank it for a few seconds first, then start it, without having to lose your tach for the trip. Which I hate. Everyone including me loves my centerpiece tach . But Entreri is right, dont shut the engine down cold.
Old 11-30-2003, 12:20 PM
Steel's Avatar
Re: flooding in fc
Or was it an S5? Either way give it a try.
Old 11-30-2003, 01:42 PM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: Re: flooding in fc
Thats for the S5, not the S4.
Also, flooding isnt normal. There is something wrong in the injection system. Most likely bad injectors. What happens is, they leak down, after the car is shut down. All this fuel goes into the intake area, and floods the car.
Read this:
http://www.mazdatrix.com/c-bleed.htm
1988 10th AE Edition TII
More mods then you have.
Old 05-07-2004, 09:05 PM
tomminajar's Avatar
tomminajar tomminajar is offline
Leaky Injectors is it - Common prob after 80,000 mi or so....
Old 05-08-2004, 12:14 AM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
Re: flooding in fc
umm... 6 months old? and was there a point?
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 05-08-2004, 04:27 AM
flex339's Avatar
flex339 flex339 is offline
Send a message via AIM to flex339
Re: flooding in fc
ummmmmmmmmmmmmmm............ nope
