Old 11-28-2003, 07:25 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Question What to get?!
For christman im getting a dremmel and a pin vice. Does anyone know what acsessories/speed/rpm's i should look for when im getting a dremel? And a pin vice. What should i look for in that? What size drill bits will i need also?
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-28-2003, 08:20 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
Re: What to get?!
I bought a black&decker rotary tool, came with a nice assortment of things, drill bits, grinding discs, sanding drums. So, I say buy the craftsman kit, it's similar to mine: L/M/H; 12krpm/24krpm/30krpm, crack the casing like mine, cause it got dropped and you can take off the governour and crank it to like 33,450rpm, then it gets real hot.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
