new rims/ speedo question
hey,
im getting some 17' rims and i was wondering if i had to adjust my speedometer because of the bigger wheel radius. if i do is it DIY stuff or should i have honda do it?. thanx, jimi |
Re: new rims/ speedo question
The trick is to PLUS size the tires to match the diameter of the stock ones. Any good tire dealer can do this for you. NO-you cannot do anything with the speedo-it is not adjustable as such.
Grandpa toys-Modded suspensions and other tweaks '89 CRX Si PDA/NASA/SCCA/Steel Cities ITA pocket rocket '99 Prelude Base SS - A Sweet Song in Motion '03 Dodge Dakota Club Cab-gonna tow the CRX |
My Prelude has 17's with the stock diameter to keep the speedo the same. P205/40R17 If that'll help you at all. BUT it winds up being very low profile, and i have have to fix dents in my rims a few times from potholes(i live in BFE). If you are spending a lot on your rims, I would either get a warranty on them (if they do that), or screw the speedo and get bigger tires. you'd have a higher top speed :o)
All the information you need is here : This is for a '97 lude, if your vehicle is different www.whalentire.com is where the info came from. STOCK TIRE SIZE: 205/50R16 Recommended Plus Sizes PLUS 1 SIZE(S) Require 17 inch wheels 205/45R17 0.19 Inches taller than stock tire 215/40R17 0.30 Inches shorter than stock tire |
