Old 11-28-2003, 02:58 PM
havnfun328 havnfun328 is offline
Question CEL Question
On my 91 DX Sedan, the CEL comes on occasionally when driving. More so lately. It always goes off after the car is turned off and sits for a minute or two, and doesn't come on again for days (at least). It seems to be running fine.
I checked the indicator light, and it flashes once every 1-2 seconds. Is this the "normal operation", or is the O2 sensor going bad?
Thanks.
Old 11-28-2003, 04:07 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
well, it could be a fault somehwere with your wiring, our cars dont have a progressive fault detector system like an OBD equppied vehicle does, but replace ur o2 anyway, its prolly like 10yrs old.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-28-2003, 04:51 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
I've had that same problem since I got my h/b (almost 4 years ago). You're getting a code 1 (O2 sensor), like you mentioned. I replaced mine & still have the problem...
Though now that I have an a/f ratio gauge, as long as I keep the car from running rich (while I'm driving) I don't get the CEL.
Old 11-28-2003, 10:11 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
another thing you may want to check out.
its been raining alot here the last 2 weeks. while i was on my delivery job, i ran through a deep puddle and about 10 mins later i got a o2 sensor cel.
try removing the "ecu" fuse in your engine bay fusebox for 15 seconds. this will reset the ecu. if you get the same cel again, i would replace the o2 sensor. make sure you get a honda o2, it DOES make a noticeable difference.
There's nary an animal alive that can outrun a greased Scotsman!
Old 11-29-2003, 06:14 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
It's one fast flash, right? Because that's a code 1. One long flash is a code 10, which is the IAT sensor. probably the O2 tho.
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 11-29-2003, 07:58 PM
Re: CEL Question
Thanks.
It's the original o2 sensor for sure. I've had the car since ~40k miles. It's now at 180k . The car is w/ my stepson. I'll replace it when I can.
One more questions. I haven't replaced the spark plugs in about 100000000000000 miles. Are they fused to the head by now? I didn't use anti-seize and I don't want to break them off.
