Old 11-28-2003, 10:36 AM
quiktsi quiktsi is offline
BOV Questions??
I was talking to this guy that builds turbos in MD, and he told that I should be venting into the atmoshere because a 14psi the surge can make the compressor wheel spin backwards hurting the turbo. Is this true?????
Next I was talking to a couple of guys at MachV in VA they told me to vent the car back into the intake because it will better no bucking or running rich. Is this tru?????
Third, they told me that the 1st gen crushed BOV is to weak to be vented into the atmosphere. If so which one do I get. They also told me not to get the GReddy type-s it is for civics with low boost.
Old 11-28-2003, 10:46 AM
97dsmeclipse's Avatar
97dsmeclipse 97dsmeclipse is offline
Send a message via AIM to 97dsmeclipse
Re: BOV Questions??
BS.....i have one and im pushing 18 psi and have no problems venting it, and its one of the louder bov in my area
Bottles are for babies - Real men get blown!!!
Car pics
97 eclipse rs - Sold
99 eclipse gs - Blown Motor
97 eclipse gs-t - For Sale
98-99 eclipse gs-x - - Looking for one
Old 11-28-2003, 01:41 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
MachV=Right
MD guy=Wrong
-Agim
Old 11-28-2003, 10:23 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: BOV Questions??
No.
Yes.
I agree the type S is a POS. I did run the TurboXS RFL vented for a while, and it worked ok. But that valve is a bigger POS than the greddy. The 1g is a very good BOV, and has damn near run 10s.
I ran the BOV vented for years, trying several valves, and several modifications to the 1G valve. I can tell you from actual expereience that yes you can vent the 1g valve if you set it up to do so, but the car will ont run at its peak with a vented BOV unless you set the mas air metering system up to do so. This means a HKS VPC, or a MAF Translator. Its that simple. Many people will step in and say "I run my BOV vented and its fine," which is fine, but if they did the extensive aquisition I have done, they would see that its really not "fine."
Just use a 1g BOV, and leave it dumped back in. Until you are ready to ditch the stock MAS airmeter system somewhere above 400 WHP and go with a REAL BOV, like the Tial, or the infamous discontinued SARD.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-30-2003, 07:26 PM
EclipsNgirl EclipsNgirl is offline
Send a message via AIM to EclipsNgirl Send a message via Yahoo to EclipsNgirl
I have a HKS SSQV bov and it is loud as hell...I absolutely love it. I can run up to 20 psi and I have mine vented to the atmosphere without a problem. Some cars it'll work, others wont. I guess I got lucky
98 Eclipse gst-race ready
95 Eclipse gst-stock
92 Eclipse GST-parts car
91 Talon tsi RWD
87 Conquest-our new baby
Old 11-30-2003, 09:36 PM
AF - Advisor
Its the sme on all cars. Datalog it and you will see that its not exactly ideal. The ones who think its ok are the ones that dont know where to look How do you know its not leaking at 20 psi? No way to know unless you pressure test the system, and compare IPW and IOT at a given fuel pressure per airflow/rev to a wideband. Every valve I have ever seen tested leaked except for the Tial and SARD (discontinued japanese valve). And in order to run a valve that large, you need to ditch the stock MAS and go with a speed density or hot wire setup. I've looked into all this extensively over many years... It all depends on your your goals. For maximum power, venting the BOV on a stock MAS isnt ideal. But yes it may run "fine."
Kevin Jewer
Old 11-30-2003, 11:25 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: BOV Questions??
i eventualy vented my type-s and the only problem i had was that it needed to be set a little harder so it wouldn't "hick-up" if i closed the throttle while the clutch was still engaged (ie 1/4 sec. before shifting). I'm not claiming more than 230 hp to my best guess (could be wrong), so i'm not sticking that much power, and only on a t-25 @ 16-18 psi, so..
Old 12-01-2003, 02:41 AM
AF - Advisor
The smaller the turbo you run, the more power you stand to lose to a vented BOV. The larger the turbo is, the more easily it can make up for lost boost withmore flow, without adversely affecting Pressure Ratio and therefore efficiency. At low boost though and a tight setting odds are you are mostly ok. The only way to tell is to do an intake pressure test (vfaq).
Kevin Jewer
Old 12-01-2003, 06:23 PM
Re: BOV Questions??
95 gsxracer is a dsm god.....
you should set up a paypal acct for donations... lmao
Old 12-01-2003, 09:41 PM
AF - Advisor
If only it was that simple
I still have a lot to learn anyway
Kevin Jewer
1st gen bov questions... Import2nr99 Off-Topic 4 01-24-2004 10:59 PM
Newbie BOV question intelligence27 Off-Topic 7 01-20-2004 10:48 AM
BOV questions.... Import2nr99 Off-Topic 20 01-19-2004 01:11 PM
bov questions thelawnmower 3000GT/Stealth 0 11-28-2003 12:34 PM
EVO 8 with BOV Question luckym85 Lancer 17 07-03-2003 06:01 PM
