Old 11-27-2003, 10:17 PM
alphalanos alphalanos is offline
I dont understand amps...
Ok if i have an Infinity Kappa Perfect DVC 350w RMS sub and it can play at 2 ohms when (bridged)? with another sub, then can i have an Alpine amp 350x1 @ 2ohms pushing both?
or can i only have one 350W sub pushed by the amp running at 4 ohms on one channel?
96 EJ6. Future home of boosted B18C1.
Old 11-27-2003, 10:45 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
What is the resistance (ohms) of the sub? You said it can run at 2ohms when bridged, but can it run 2ohms by itself, or is it a 4ohm sub? An amp that runs 350x1@2ohms will probably not be able to push 350x1@4ohms. I'd get a stronger amp if you're planning on bridging in more subs, but without any more information, I can't really tell ya anymore than that. sorry.
Old 11-28-2003, 02:28 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: I dont understand amps...
you bridge an amp, not a sub
My guess is those subs have a dual 2ohm VC setup (based on what you said). When you wire each sub in series they are 4ohm each, then you wire the pair in parallel to a final load of 2ohm. You hook the pair up to the amp that puts out 350x1 @ 2ohm and you get 175 per sub. As long as the subs are dual 2ohm, the amp really does put out 350x1 @ 2ohm, and 175 will drive the subs nicely, then it should work. If you could give model numbers or links to the actual products we could help you more.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-28-2003, 04:41 PM
Sub: http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
Amp: http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
I actually plan on having only one 12" Perfect but depending on how they can be powered i might get two. (if i can use one moderately priced amp($200-500) as opposed to two amps(easily reaching $1000 and higher) besides i have a hatchback so i dont need massive power. just enough to sound good in and near the car.
Old 11-28-2003, 09:33 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
you can possibly blow one sub with that amp, based on the fact that alpine underates their stuff. you can only power one sub with that amp also
Old 11-29-2003, 07:54 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Re: I dont understand amps...
NO ...... just because the amp is one channel, does NOT mean it can only run one sub.
Old 11-29-2003, 06:07 PM
Haibane's Avatar
You missunderstood what I meant by what I said, I was saying it doesn't have enough power to power it the way he wants or stability
Old 12-01-2003, 01:27 AM
sr20de4evr's Avatar
If you only get 1 sub then that amp should drive it nicely. If you want to get 2 subs instead, then you should look for an amp that does one of the following:
350x2 @ 2ohm
700x1 @ 1ohm
700x1 @ 4ohm
Any of which should be fairly easy to find
Also, crutchfield has a decent selection, and exceptional customer service, but their prices are rediculous. You can find the same items for nearly half that if you shop around or look on ebay. Some of my favorite places:
www.ikesound.com
www.sounddomain.com
www.woofersetc.com
'01 Black Sentra SE
'05 Silver WRX STi
