what's a nice exhaust system and place to get them from for a reasonable price. i kinda just wanna know what the selection would b from.
Re: exhaust
See the "New owner of a 97 Aurora" thread.
Quality isn't expensive, it's priceless. |
just run straight pipes dude sounds bad ass and only cost me like 90 bucks to replace the mufflers and resonator.
[On his running for California Governor] It's the most important decision I've had to make since 1978 when I decided to get a bikini wax. -- Arnold Schwarzenegger Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book. -- Ronald Reagan "I wrote a book" --Bill Clinton |
Re: exhaust
He said NICE exhaust!
Im thinking about removing the resinator when I have the Flowmaster DeltaForce 50 series mufflers put on, has anyone done this? Will it have an adverse affect on interior exhaust noise?
BKVic Last edited by BKVic; 11-29-2003 at 06:44 PM. |
Re: exhaust
Indy8
From what Ive read the resonator is nothing more then a very high flow muffler, do you have any idea If I would gain anything If I replaced it with a aftermarket unit. Does it flow well enough that any added flow wouldnt be worth the moneym put into it. BKVic |
Re: exhaust
True, it's nothing more than a luxury car baffle to quiet it even more. The people that have removed it said it was louder inside the car at constant speed. The thing is, all high performance(even less restrictive) ones, are 3" in and out. Requiring you to change the whole center pipe from the cat. conv. back to the "Y", which would then be a whole cat-back system. So.... either go 2.5" from the "Y" with nice mufflers and be happy with it(about 10HP), or spend the big bucks and get a dyno proven cat-back system, like the Corsa(18HP). The people that have tried to piece together their own systems have had problems in different areas. Some lost mid-range power, while others were happy with power but the SES light would come on every time they got on it. Not enough back pressure and the O2 sensors think it's lean. Anyway, that's my take on it.
Re: exhaust
indy8
where exactly r u planning on getting ur muffler at? is there a certain site that has the best price on it? |
Re: Re: exhaust
I have not started price shopping yet. I measured the stock muffs and then found the closest match on Magnaflows website along with the polished S/S tips that have the stock shape,#35175. I'm not so concerned about price as I am about finding a GOOD shop that can do Mandrel bends and knows how to properly weld S/S(it is different).
Re: exhaust
what size is the stock pipe? 2.25?
Re: Re: exhaust
I put a set of OD calipers around the "Y" to muff pipe and I think it was only 1.875(1-7/8).
Re: exhaust
Thanks indy
Um ....would it be ok you think to just cut out the stock muffs. and clamp in new Flowmasters or Dynomax. I mean I know I'd prolly get better sound but would I see any hp gains? |
Re: Re: exhaust
I would never recommend clamping. It really should be welded and it's cheap labor($20-$40). Plus, you will have to have a transition pipe welded on anyway. Most high performance muffs are 2.5" inlet. A muff shop will have tapered tubing to go from the stock pipe diameter to the muff inlet. I think Greg Garnes did some dyno tests, and reported 8-10HP gains just by getting rid of the stock "grandpa approved mufflers".
Re: exhaust
cool thanks
