Old 11-27-2003, 07:07 PM
caminokilla420's Avatar
caminokilla420 caminokilla420 is offline
Send a message via AIM to caminokilla420
welding.....
ok i have a 1979 el camino and its got body rot by the rear wheel well by the muffler and i plan to cut out that rusted area and cut out a peice of sheet metal and mold it to orignal shape and tack weld it in but probem is i dont have a welder, i do have a sotering gun and some solder that is lead free can i use that to tack it in please help
(not mine i found it on some website) find me im falling and fooling myself thats its flight imperfect i plumit and ponder pushed away on principal
Old 11-28-2003, 02:44 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
I'm no body man, but soldering your body doesn't seem like a good idea to me. Solder wont hold very well in your application. Get someone to weld it.
Beer tastes better upside down.
Old 11-28-2003, 09:31 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Re: welding.....
You can buy a wirefeed (flux core) welder for about $150 that would do the job.
Old 11-28-2003, 01:43 PM
i saw some stuff they were using to repair boat holes and small holes in metal and stuff it was called uhhh amuma something i dunno but it comes in like a stick and u have a propane blow torch and u heat up the metal and then u like weld the 2 together by rubbing the stick between the 2 peices of metal u want to connect and it is suppost be stronger than alumium will that work?
Old 11-29-2003, 04:29 AM
All I know is that body shops use welders. You would think that if there was an easier, cheaper way, they would use that. But for all I know it could, if you decide to go ahead be sure to tell us your results. I would love to know if it works.
