Old 11-27-2003, 03:39 PM
shaggskilla shaggskilla is offline
Send a message via AIM to shaggskilla
wont start in cold, wet plugs
OK, its a 92 3.1L v6 and i have this problem where it wont start in the cold....and when i pull the plugs, they are all wet with gas...i dry them off them put them bak in and the car starts right up...whats doin this??its takin me to the conclusion that i should just sell the car.....
Old 11-27-2003, 05:31 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
Re: wont start in cold, wet plugs
u sure its gas not water, cuz thats a whole nother story there...
Just for the Stroke of it...
Old 11-27-2003, 10:13 PM
smells really strong like gas on the plugs.....what do u do if its just water though.....?
Old 11-27-2003, 10:58 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
well, first thing, check to make sure your battery is charged, and it is a heavy duty battery, it also depends on what you concider cold, in very cold instances, the charge in the battery can be half its advertized rating, meaning it will crank slow, and may not fire the plugs. also, check your spark plug gap and make sure its to the factory spec. and most important, make sure you have spark, but if it runs in the warm weather, then i dont think thats the problem, my best guess would be the battery, unless its water, in which case the best think i know of to do, which may not be the best course of action, is to drain the tank, throw in some dry gas additive, and a full tank from a high quality gas station, i use texaco or ammco.
Old 12-10-2003, 09:45 PM
Nothin
Still nothin has worked....had to stand out in the cold and rain tonight and pull all the plugs and dry them.....def. gas is wettin them down....it seems if i crank it and it tries to start then the plugs get wet and it wont start.....but if it doesnt try to start the first time then it starts the second time.......??
Old 12-10-2003, 10:04 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Try having your car jumped. If that works the first time, then it's your battery. Your plugs being wet with gas is caused by fuel not igniting and your just dumping gas in there. If the jump doesn't work then your running way way way to rich, and your flooding your motor. Kinda wierd with multi point injection, but could happen. Check your fuel pressure regulator, injectors, intake, hell your whole induction and fuel systems.
