Old 11-27-2003, 01:54 PM
94civic94 94civic94 is offline
Send a message via AIM to 94civic94
cheap upgrades
i have a 94 civic and need to know a few cheap upgrades ne suggestions or something even not cheap put em up
Old 11-27-2003, 08:44 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: cheap upgrades
Yeah you should get a SEARCH, its good for about 10-15 hp if done right.
Check out my car here My 91 Hatch
Old 11-27-2003, 11:41 PM
PhilipD PhilipD is offline
cheap? probably nothing. just save up for suspension and wheels, or swap, or if you have an ex (d16z6) save for turbo
or if you want you can get i/h for the z6, exhaust is good too, nothing really cheap
Old 11-29-2003, 11:58 PM
SOHCD16y8 SOHCD16y8 is offline
Re: cheap upgrades
I cheap upgrade would be a test pipe, it will add 10-15 HP and replaces the cat. It is not street legal and will not pass emissions but u only have to pass once every few years. The exhaust will get consideribly louder. You can get one from http://www.racingpipes.com/honda.html You will want one without an O2 bung for your car. Easy to install and only cost about 30 bucks
Old 01-10-2004, 04:49 PM
Kinked210's Avatar
Kinked210 Kinked210 is offline
Send a message via MSN to Kinked210
Re: cheap upgrades
Intake/Header/Exhaust first off...
You could get some really cheap stuff from ebay for like $400 for the I/H/E total. But thats like cheapy stuff.
Old 01-11-2004, 01:54 AM
asterox's Avatar
asterox asterox is offline
i just asked the same question if you look down the page under a post titled 'recommendations'
to summarize...
check out the board FAQ and the engine swapping guide, both give you a sense of your options
if you have a dx/lx/cx with a 102hp motor you can get an extra 23hp by swapping in an vtec engine from the ex model of the same generation. more important is the extra torque you will get at the upper range of your rpms.
ex engines can be had for <500 dollars, all other swaps will run 2000+
bolt-on parts (exhaust, header, intake) are comparitively easy to install and will give you a small hp boost and change the sound of the car
you don't have to buy a full cat-back system to change the sound... swapping the engine would be a good crash course if you have someone knowledgable at hand
