Old 11-27-2003, 09:21 AM
crackerhead crackerhead is offline
Cast Aluminum Oil Pan
Hey, everyone!
Does anyone know the nominal wall thickness at the bottom of the oil pan sump? My engine is an '02 6.0 litre in a Silverado 2500 HD 4WD.
In GM's infinite wisdom, they put the drain plug at the rear of the pan, directly in line with the exhaust. A real PITA, you know. I tried a Sure Drain fitting, and it sucks! I'm thinking that with the room between the skid plate and the pan, maybe I could drill and tap for an alternate type of drain on the bottom, where it should be.
Has anyone modified their pan in this fashion? Any Ideas? Am I being a Dufus for even wanting to try this?
Thanks in advance for any info!!
Happy Thanksgiving!! Bryan
Old 06-02-2004, 10:46 PM
altimax altimax is offline
I'd say leave things as they are. My pan has a crack in it near the plug. note that where the plug seats, the casting is thicker and machined, but mine is a mess - chunks missing. dealer says they have never seen the problem before and attribute it to a bad casting - problem is it's 4 years old and out of warranty. They are the only ones to have changed the oil, so if it ain't a bad casting, then it's bad mechanics. Hopefully some goodwill warranty will kick in, 'cause it sure isn't anything I've done.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 09:39 PM
