Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 11-26-2003, 08:34 PM
YoungDion YoungDion is offline
is it true about these 240sx's
I was talking to a friend of mines and he told me to put a sr20 into a 1995 240sx, I'll have to change the rear end beacuse that motor will break it. He said I'll have to send the eecu for that motor to jim wolf to reprogram it or the car won't start after i make the swap. He also said that it is much harder to swap engines, because it's not like a honda engine, dropping it in and pluging it up and turning it on. Is it really a lot of work
I need some advice on which motor to do up. Sr,Ka,Rb? I just want to be able to spank some Gsr's and Si's with turbo. How much am I looking at spending. Where are some good places to go and peice this monster together? prices on the stuff i need would do me some justice.
Old 11-26-2003, 08:43 PM
Jay! Jay! is offline
Horizontally Opposed
Re: is it true about these 240sx's
Welcome to AF. Look here:
http://www.automotiveforums.com/vbul...ad.php?t=92927
Hierarchy of Subaru:
(Click to see mine!)
Old 11-26-2003, 08:51 PM
Suislide's Avatar
Suislide Suislide is offline
thanks jay.
dude, don't just go on what your friend is telling you. that's usually a bad idea. just because he says it's a cool car and tells you to do a certain swap doesn't mean it's the car for you or anything like that. do some research first and then decide.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 11-26-2003, 08:53 PM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
Is your friend a honda fan?
A S14 sr20 will swap right into a S14. You wont need to send the ECU anywhere (though Jim wolf might be able to squeeze a bit more power out of it), and the rear end will be fine.
The only real difference is honda engines are so small you can just lower them into the bay and bolt it up. A SR20 is a RWD engine so it will be harder to maneuver into the bay.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
