Go Back   Automotive Forums Car Chat > Cadillac > General Discussion
Old 11-26-2003, 05:25 PM
hidroela hidroela is offline
no power on the injectors
I have a 91 sedan Deville Cadillac that not wants to start due to no power on the injector coil
Does that mean that the engine control module is defective and has to be replaced
There is gas going to the injectors
There is power on the spark plug
The starter work
The wiring in between injector and ECM are good
Any help would be appreciated
Old 11-28-2003, 02:56 PM
O1CAV O1CAV is offline
It Probaly Is The Ecm,that Controls Injector Pulse,try And Pull
It Out And Tap On It With A Screw Driver(it Is Under The Pass.
Side Kick Panel And Should Be Held In By One Or Two Ten Mil Bolts) And Try To Start It.
Old 11-29-2003, 01:43 PM
thanks O1CAV
O1CAV thanks for you advice i will try now
