Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 11-26-2003, 02:42 PM
mybuggy mybuggy is offline
Turn Signals Not Working
My Turn signals stopped working along with the rear bumper side marker light on the passenger side and the hazard lights. All of these don't work. I was wondering if it's my fuses or something else causing these not to work.
Old 11-26-2003, 06:05 PM
Also, the turn signal bulbs are still good because they light up when I disable/enable the factory alarm system.
Old 11-27-2003, 01:52 PM
mechy1barry mechy1barry is offline
Re: Turn Signals Not Working
couple of things to look at are~hazard switch,is it possitive in its opperation? try gently rolling switch and see what happens.flasher relay~poor terminals,or just worn out,try tapping it.has it got power.?
Old 12-22-2003, 09:39 AM
bbokish bbokish is offline
Question Re: Re: Turn Signals Not Working
Where is the flasher relay - how do I get to it? My wife's Beetle has a similar problem. The turn signals & flasher speed up, slow down, stop - very erratic.
Old 12-22-2003, 01:45 PM
you can find it simply by turning ignition on,operating flasher,and listening for the clicking of the relay.
Old 08-10-2005, 03:32 PM
msbmsb msbmsb is offline
location of flasher relay
Can someone who has replaced their flasher tell me where it is located?
I've replaced a couple on Fords before but never a VW. It's a friends car so I haven't been "under the hood" much. Is it located under the dashboard (access from driver's floor area?
Thanks.
_Mike
Old 08-11-2005, 08:01 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
The relay is the actual switch itsself. You have to replace the switch.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
