Old 11-26-2003, 01:11 PM
Johannes Johannes is offline
Banned
Fused horn
I have an air horn in my truck, but it's not fused or anything. Basically the compressor and the horns sit under the hood, with one wire going to the battery, and the other wire going thru the firewall to a switch, and then coming back off the switch to the battery. How do I determine what kind of fuse I need and how do I install it?
Old 11-26-2003, 02:52 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
an inline fuse holder would be your best bet. Radioshack has some for 2-5 bucks. I prefer the glass tube fuses (AG type), but that's just me. I find them easier to replace. I don't know the amperage you should use though
Old 11-26-2003, 04:56 PM
Banned
Do I fuse the neg wire or the pos... does it have to be on the wire coming from the switch?
Old 11-27-2003, 12:09 AM
Diesel2NR's Avatar
you'll want the switch and fuse on the positive wire. The fuse should be within 18 inches of the battery and the switch can be where ever you want it. Good luck!
Old 11-27-2003, 11:54 AM
Banned
Okay I think right now my pos wire runs straight to the battery and the switch is on the neg wire... guess I'll have to adjust that
Anybody know about the amperage to use for the fuse?
Horn Problem... XeroInfinity ebreiner Grand AM 15 08-01-2013 11:12 AM
97 VW Jetta Horn HOnks intermittently aaronsheddrick '97 - '03 2 11-09-2009 11:13 AM
Bigger, louder than any horn! BOB SWANSON General Discussion 0 03-27-2009 11:09 PM
20Amp fuse, horn and brake switch issue?? ladybug44 Accord/TSX/Accord Hybrid 6 11-23-2008 09:39 PM
