Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-26-2003, 10:52 AM
iwin12 iwin12 is offline
Loss of power under load, 1992 SSE
Please reply even if different model year. I have SSE with 3800 non- supercharge engine.
Problem: Check engine light comes on after sitting overnight. Goes off and stays off after restarting. Acts like trans is slipping or too much/too little gas (looses power after 3200 RPM). If I back-off and accelerate moderately (under 3000 RPM) you would never know there was a problem.
Note: Problem gradually goes away and car drives normally for most of the rest of the day. Occasionally will be driving normally and "BAM" it's like you hit a switch and acts-up with loss of power just as decribed above.
Old 12-07-2003, 08:21 AM
This turned out to be a diagnostic code 42 problem. had to replace the ECM (computer) and the ignition module.
Old 12-07-2003, 12:23 PM
markwb's Avatar
markwb markwb is offline
Re: Loss of power under load
Did that clear up the symptoms?
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
96 F-250 460 loss of power under load jwalker1970 F Series 10 10-01-2009 09:09 PM
Rough idle loss of power under load rteas48183 Problem Diagnosis 0 03-17-2008 09:40 PM
NO power under load, backfires thru carb, overheats. shuttelbay1 Lumina 10 12-27-2004 01:03 PM
