Old 11-26-2003, 10:52 AM
boots03 boots03 is offline
Send a message via AIM to boots03 Send a message via Yahoo to boots03
"new" car blues
well, i have just purchased a 1985 Iroc-Z with the 305 TPI and the 700R4 Tranny, well, between 2,000-3,300 i hear a popping coming from the air box, and when i put some weight on it, the popping gets worse, i was wondering if anyone knew how to fix this. also, can some one show/tell me how to adjust the linkenge on the tranny so the shifter lines up with the plate, i.e, its a bitch to get into park
thanks
~boots
Old 11-27-2003, 11:29 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: "new" car blues
only thing i can think of for the airbox, is that something somewhere is loose, aside from that, dunno boss
Old 11-30-2003, 05:54 PM
Re: "new" car blues
acually its worse, its popping out of the intake, do you think the timing could be off a tooth or two??
Old 11-30-2003, 08:16 PM
89IROC&RS's Avatar
Re: "new" car blues
unless the engine has been torn apart and rebuilt, then its more likeley that someone pushed that 305 too high and burned a valve or something, i would run a compression test and see if all your cylenders are even, and at around 120-140 psi, im not sure exactly where it should be, but they should be the same. if you have some that are low, its either burned up rings, or burned valves, burned rings would cause a misfire, and stumbling, and burned intake valves cause the backfire out the intake trac. thats where id start.
Old 12-01-2003, 04:05 AM
Re: "new" car blues
it has had a topend rebuild, and a newer accel hei ignition
Old 12-01-2003, 08:33 PM
89IROC&RS's Avatar
Re: "new" car blues
hm, well then, im stumped. sorry
Old 10-24-2004, 10:45 PM
cobra1 cobra1 is offline
old thread.... but did you ever get this figured out?
the old lady has a 93 Corsica doing the same thing. it runs, but running at speed, or if you gun it in idle its popping through the air box.
"new" car, please help! iceiso Mustang Talk 5 04-11-2005 12:36 PM
My "NEW" Car! DasBoot LeSabre 7 06-23-2003 10:11 AM
My "new" car!! 76_cobra Street Racing 2 11-13-2002 03:06 PM
My "new" car!!! Jays76Camaro Camaro Discussions 7 07-26-2002 03:57 PM
