Old 11-26-2003, 09:20 AM
Guichet Guichet is offline
Bright Lights Question
Have you ever noticed that when you engage you bright lights that for a breif moment while the blinker is depressed all your lights are on. Is there an override to make this happen whenever you turn on your bright lights?
Old 11-27-2003, 08:30 PM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
Re: Bright Lights Question
Cut Ground Wire coming out of Headlight bulb. Attach the ground wire coming out of the bulb to a ground. (I attached the wires under some exsisting screws near the headlight.) (Do this because when you hit your high beams, the BCM (Body control Module) turns the ground to the low beams off, but leaves the power wire hot.)
Old 12-01-2003, 01:38 PM
Which wire is the ground wire? I had heard that there was an aftermarket module to enable this to occurr.
2000 sunfire bright light problem mazer Cavalier Problem Diagnosis 7 09-26-2006 12:17 AM
bright lights justlearning Camaro Discussions 3 01-05-2005 01:42 PM
bright light switch bob8748 Town Car 3 09-16-2004 04:59 PM
Bright Lights Indicator mrlong Caravan | Voyager 0 06-26-2004 10:10 PM
Bright lights eric gonzalez 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 07-27-2003 03:16 PM
