Old 11-26-2003, 09:02 AM
DaveCovenant DaveCovenant is offline
Transmission Problem??
I had just bought a '93 Firebird Formula automatic a month ago. I was driving down the road and from a stop light I noticed that I wasn't really going anywhere. The car moves from 0 to 5mph alright...,but after that it doesn't move. The RPMs continue to rise and the engine gets warmer, but there just seems to be nothing I can do to make it move faster than that 5mph...I've tried it both in the overdrive and from 1st, 2nd, and 3rd...nothing seems to work...I then checked transmission fluid both hot and cold and it seemed to be low so we filled it...followed the directions form the manual with the gears and idle, but the car still doesn't move.
Is there another place that I can directly put transmission fluid (other than the dip stick spout) or does someone think it might be something else?
Thanks,
Dave
Old 11-27-2003, 07:22 PM
xlwhellraiser xlwhellraiser is offline
Send a message via Yahoo to xlwhellraiser
Hey, I am not sure if this will help, but you might want to check under the car if all of your hoses from the tranny are connected and/or loose. The hoses might be the ones that are causing the leak. If not than you are probably looking at a more serious problem.
I hope this helps.
Old 12-03-2003, 06:49 PM
69bird 69bird is offline
Send a message via ICQ to 69bird
Re: Transmission Problem??
Thanks,
Dave
If your low on fluid it's not gonna move. add fluid in dipstick hole til it's up to full level. don't overfill. too much is worst than not enough. If trans still doesn't shift right your filter might be clogged. Filter should be changed about every 30K miles. fluid should be cherry red and shouldn't have a burnt smell. if it smells burnt, time for a rebuild.
Alarmed by website highlighting Honda Odyssey Transmission Problems LibertyLoudSpeaker Odyssey 1 07-09-2010 03:03 PM
2003 GMC Sierra 1500 5.3 Transmission Problem kkaupang Sierra 1 05-19-2010 09:58 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Transmission Problem SeanCL Cobalt 3 09-15-2009 08:16 AM
