Old 11-26-2003, 01:41 AM
[GTO][Antiks] [GTO][Antiks] is offline
Blow Off Valves
Hi, almost all my freinds have blow off valves and i was just woundering if anyone could tell me how they work, and also all the cars i see them in are manual and i wanted to find out if i could put one in a auto
thanx
Old 11-26-2003, 08:22 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
The Blow off valve (BOV) is on the turbo charged cars. They are used to release the air pressure out of the intake system when the throttle is closed quickly. They help control boost response and extend the life of the turbos.
The reason that they are on manual cars is because the VR4 (GTO) only comes in a manual.
Resistance Is Futile (If < 1ohm)
Old 11-26-2003, 10:49 PM
Re: Blow Off Valves
Yea but can they be put in a auto???
Old 11-26-2003, 11:19 PM
YogsVR4's Avatar
Re: Re: Blow Off Valves
The transmission has nothing to do with the BOV. Its all part of the intake system of a turbo charged car. If you have a turbo in a car thats an automatic, then it can and will have one.
I just made the leap that we are talking about 3000GTs here. There are no turbo powered automatic 3000GTs (from the factory).
Old 11-27-2003, 01:03 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
listen to the great yogs, he know what he's talkin about!
Old 11-27-2003, 01:41 AM
Re: Blow Off Valves
Yea i picked that up from the the other threads, damn man u know your stuff.
Old 11-27-2003, 01:57 AM
Re: Blow Off Valves
Yea i just got wind of a cheap 91 VR4 and i was woundering should i just stick with the SL because im gonna go to the legal drag strip and the awd section is gonna be hard to beat (thay run the 1/4 mile at low 11s). but the 2wd is way eazer (they run at high 13s). so would it be eazer to get my SL to run 13s or the VR4 to run 11s
Thanx
Old 11-27-2003, 03:46 AM
youngvr4's Avatar
STREET RACING GURU
i'm gonna go with vr4 to 11's cause a sl runs like a 16.5 and to get it down to 13's with no turbo is gonna be hard, with the vr4 turbo upgrade bc intake dual bov exhaust clutch trans, i guess either way its gonna take some pretty change.
Old 11-28-2003, 12:51 AM
The1NamedMarc's Avatar
The1NamedMarc The1NamedMarc is offline
Send a message via AIM to The1NamedMarc
Re: Blow Off Valves
You could get a VR4 running high 11's with about 6 grand... That's also assuming you can install everything yourself.
Old 11-28-2003, 06:20 PM
Re: Blow Off Valves
So it looks like im gonna go for the VR4 then, what would i do to make it run high 11s???
Old 11-28-2003, 06:21 PM
Re: Blow Off Valves
So it looks like im gonna go for the VR4 then, what mods would i have to do to make it run high 11s???
Old 11-28-2003, 06:23 PM
Re: Blow Off Valves
and what would it cost me with instollation costs?
Old 11-29-2003, 01:09 AM
Dr650s
660cc
MAFT
Fuel pump
re-wire
BOV
Stage 2 Heads
DP
y-pipe
That'll run you about 6K... (I couldn't tell you about installing price b/c it depends on the place) You don't need the Stage 2 heads unless you really want mid 11's. There are other combos you can do, that's just a quick one I made.... Check www.dynamicracing.com for more information on their different stages.
Old 11-29-2003, 01:23 AM
Re: Blow Off Valves
OK, thanks for the info
