Old 11-25-2003, 10:25 PM
POScar49 POScar49 is offline
headlight bulb problems
im having trouble with my right headlight bulb. wenever i put in a hyper white it blows within 2 months. only the right side too, ive never blown one on the left side yet. its weird...
Old 11-25-2003, 10:46 PM
gsf1200m gsf1200m is offline
I had that problem with my regular bulbs, always the right not the left. Then I got projectors and havent had that problem since.
Old 11-25-2003, 10:54 PM
Old 11-25-2003, 10:56 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: headlight bulb problems
Are you touching the glass part of the bulb before you install it?
Check out my car here My 91 Hatch
Old 11-27-2003, 01:28 PM
nop
Old 11-28-2003, 02:42 PM
BlueCivic83's Avatar
BlueCivic83 BlueCivic83 is offline
Send a message via AIM to BlueCivic83 Send a message via Yahoo to BlueCivic83
maybe you should chek the voltage of both bulb harnesses and see if the right one is putting an execively higher voltage...
Old 11-28-2003, 03:34 PM
cot's Avatar
cot cot is offline
any chance the ground is flaky on the one bulb?
if it were something that wasnt solid, maybe the light flickering a bit would be enough to prematurely age it (light bulbs dont like being turned on and off a whole lot)
not sure but maybe the flickering could be so fast/subtle that you wouldnt notice it visibly
