Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-25-2003, 10:02 PM
mattbrye mattbrye is offline
compression ratio?
Everyone is saying an Ls integra is the best to turbo b/c of the lower compression ratio....how does that work? I dont understand what compression ratio really is..and please explain also why one is better for a turbo and the other is not..thanks this will help alot.
Old 11-26-2003, 08:26 AM
TEAM KLR's Avatar
TEAM KLR TEAM KLR is offline
Send a message via AIM to TEAM KLR
Re: compression ratio?
compression ratio is how much the pistons compress the fuel and air when they come to TDC "top dead center" the higher the comp the more power, with a forced induction set up the turbo or supercharger effectivley increases the compression. in racing applicatoins you typically go with low compression 7 or 8 to 1 comp and crank the boost way up, street applications we have found that you are better to go alittle higher and run less boost.
