Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 11-25-2003, 07:17 PM
plarivesr plarivesr is offline
Unhappy irrattic idle, lurching, surging
I have a 99 Sable LS with 3.0 24V DOHC.
I just had my transmission rebuilt. ($ 1900.00 - OUCH!!!)
I have the following problems:
1.Idle goes between 750 - 625 -750 etc....
2. While driving on interstate have some surging
ie: like it's gear searching
3. When I stop my dash, radio, etc... lights go out. When I accelerate they come back on.
4. Had code test done. No faults shown. :-
Help Pleasssseeee????
Old 11-30-2003, 12:05 AM
bd7js bd7js is offline
Send a message via AIM to bd7js
I have the same car, same problem. I have been told the problem is with either a broken vacuum line, or a clogged EGR valve. I plan to check on these this week and figure out next steps.
Anybody with some ideas, please advise!
Thx... BD7Js
Old 12-14-2003, 09:53 AM
[email protected] jjgsix@aol.com is offline
Check throttle postioning sensor?, or speed sensor? check error codes immediately after problem occurs (computer may clear codes after driving for a time).
If your rebuilt tranny has a warranty bring it back and have it checked out!!
Old 12-31-2003, 01:25 PM
Re: irrattic idle, lurching, surging
Thx... BD7Js
--UPDATE--
I replaced the PCV hose, and cleaned out the PCV hose - runs smoother and no longer dies...
Thx
Old 12-03-2007, 04:10 PM
gointodeepwater gointodeepwater is offline
Smile Shutter, lurching, surging
Took my 2001 Mercury Sable to the local shop and let him drive it. My car would sometimes drive ok but on occassion would surge or shutter. I would watch the RPMs change and it looked like the transmission may be trying to shift in and out of overdrive or even an ignition or fuel problem. I did the cheaper stuff first. Replaced fuel filter - No change. Replaced Spark Plugs - No change. Replaced Plug Wires - No change. My mechanic road tested it and he thought it was the Torque Converter. I asked how much it would cost and he said maybe $6.00. When we got back at the shop he brought a tube of Dr. Tranny Instant Shudder Fixx and put it in the transmission stick tube. Within 1 mile of driving the shutter was gone.
Old 08-15-2008, 09:40 AM
Avery70815 Avery70815 is offline
I had my inline air filter changed on my 2001 Sable Duratec 24v at the Ford dealer and they broke the plastic throttle cable grommet that is next to the air filter. Several days later it caused the car to accellerate rapidly and I had to pull over and turn off the ignition. Turned it on again and rpms went very high and damaged my tranny to the tune of $900 for blown seals.
98 240sx rough or surging idle & worst fuel millage Ghern 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 04-27-2010 04:34 AM
'90 mustang will bad fuel pressure regulator cause idle surge? fords4me Mustang Problem Diagnosis 1 11-27-2009 02:18 PM
97 bonneville stall,irrattic idle sdp Bonneville 5 04-16-2004 07:08 AM
97 Bonneville stall,low idle,irrattic idle sdp Trans Sport 0 04-06-2004 08:14 PM
87 Prelude SI Idle is surging fritcr Prelude 11 02-26-2004 02:14 PM
