Old 11-25-2003, 03:16 PM
mtdxx mtdxx is offline
high beam problem?
low beams work, high beams do not. When high beams are on there is no voltage to the lights (at the headlights). Where do I check next? could it be the switch, or is there anything else to check. \
I am going back out to freeze my ass off and check the fuses and relays (if any). Please help.
Old 11-25-2003, 08:30 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
It may be the switch in the steering column that turns them on. Maybe try spraying contact cleaner in there, and flipping it on and off. Do this repeatedly a few times, It fixed my old car (an 88 accord) that was doing similar things (only the brights would come on sometimes when you pulled the lever).
Old 11-26-2003, 11:26 AM
Duatone Duatone is offline
if your not getting any juice to your headlight harness, then you are correct to check your fuses and/or relays.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 11-26-2003, 11:52 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Re: high beam problem?
There is a fuse for each light though, so unless they both coincidentally blew at the same time it probably won't be them. Check the relay or the actual switch.
Old 11-26-2003, 02:13 PM
relay is okay, fuses okay. I do not think the switch is working. However, I am now told that the car's radio flickers on and off and has been doing so since the high beam problem...
When I get the car again I was going to pull the radio out and check for bare wires maybe interfering with the headlights, I do not know. Maybe it is a separate problem in itself. I do not want to just replace the switch and then not have that be the problem. I am not good with electrical.
I'm close to just sending it to a real garage.
