Old 11-25-2003, 01:18 PM
jazer80 jazer80 is offline
wiring radar detector
where would i wire my radar detector to if i wanted it to turn on when the car turned on? could i put it to the wire that turns on my stereo when the car goes on?
Old 11-25-2003, 03:04 PM
JakeDrummer JakeDrummer is offline
Send a message via AIM to JakeDrummer Send a message via MSN to JakeDrummer
doesn't your lighter socket turn on and off with the ignition? it does in most cars.
94' Integra GSR - Built and Boosted.
95' GMC Sierra 1500 Z71- Business Vehicle.
89' GMC Sierra 1500 4x4 - NV4500 Donor, Mud truck.
94' S-10 - Winter Beater.
98' Jetta - Wife's Car.
81' Kawasaki LTD440
OLD/SOLD CARS: 93' Civic (Sold 124k) -- 91' Civic (Dead 300K) --
91' Civic (STOLEN) -- 92' Civic (Donor) -- 90' Caravan (Dead 227k) -- 89' Civic (Sold 289k) -- 90' Accord (Sold 265k) -- 96' Corrola (Dead 174k) -- 99' Beetle (Sold 134k)
Old 11-25-2003, 04:18 PM
ya but i don't want the wire hanging over my dash
where else could i hook it up?
Old 11-25-2003, 07:01 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: wiring radar detector
here's a little how-to on hardwiring your radar detector www.grandamgt.com/radar.html
Empty Pockets Racing Member #1
Old 11-25-2003, 07:32 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
thx for the hardwiring tut.
i'll be needing it when i finally get my radar.
Old 11-25-2003, 10:53 PM
60hz163.5db's Avatar
60hz163.5db 60hz163.5db is offline
hhmm well as for removing the A pillar cover which if you are unsure is the peice of plastic that runs down the side of the windshield. To remove it simply start at the top pull it straight out do not force it work at it if it's being tough.
As for wiring it to the radio fuse i don't recommend this due to it being 10a or less. Sometimes radio's will pull high current at loud volumes and especially if it's aftermarket. Check the owners manual and find a fuse that is marked ignition or accessory it will be larger around 15-40a. As for tucking under the headliner some the edge will just pull down with the fingers and others you will need to use a flathead or panel tool to "help" it under.
"Working in car audio has it's advantages, but it also shows you how much money ppl have to waste."
