Old 11-25-2003, 01:10 AM
tokes99's Avatar
tokes99 tokes99 is offline
Need some help crx will not start?
I changed the plugs, wires, charged the battery but nothing? It died on me after I drove around the block and idled it in 1st has not started since? A firend told me that I sholud probably change the ignitor because it has over 130k miles on it, any other suggestions?
Old 11-25-2003, 01:51 AM
BullShifter's Avatar
Re: Need some help crx will not start?
Was your car running fine before you worked on it?
http://www.binghamtonlife.com/manual/2gsm/default.htm
Old 11-27-2003, 12:40 AM
tokes99's Avatar
Actually the battery was weak and I had to get it jumped on a couple of occassions but I have since charged the battery and nothing. Is the ignitor just another term for the distributor?
Old 11-27-2003, 01:58 AM
No the igniter is inside of the distributor. It could be the igniter, ignition coil, main relay, & many more things. Does the fuel pump come on when trying to start? Have you checked for fuel pressure & spark?
Don't replace parts unless you know their bad or will make your car faster.
http://www.binghamtonlife.com/manual...s/91-23-56.jpg
http://www.binghamtonlife.com/manual...s/91-23-63.jpg
http://www.binghamtonlife.com/manual...s/91-23-55.jpg
http://www.binghamtonlife.com/manual...s/91-23-64.jpg
http://www.binghamtonlife.com/manual...s/91-11-22.jpg
http://www.binghamtonlife.com/manual...s/91-11-24.jpg
http://www.binghamtonlife.com/manual...s/91-11-25.jpg
http://www.binghamtonlife.com/manual...s/91-11-92.jpg
http://www.binghamtonlife.com/manual.../91-11-111.jpg
There are some links to get you started.
Old 11-27-2003, 05:04 AM
mrchris1979 mrchris1979 is offline
I had the same problem on my Del Sol. It turns out the distributor bearing just seized up. This happens on high milage distributors. To check on your car, Take the distributor off the head and spin the rotor on the distributor that goes in the head. If it spins freely then it is not the problem, if it hesitates or does not spin at all, replace the entire distributor cause you cannot just replace the bearing. I got a used one from a junk yard. As long as the rotor spins it is okay to use. Basically, if the rotor does not spin, the spark plugs do not ignite.
Old 11-27-2003, 11:28 AM
tokes99's Avatar
thanks for the info
2000 Alero V6 will not start. Please help. slavetothought Alero 1 10-28-2010 08:45 AM
Help car will not starts Capecoral240 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 12-24-2006 10:57 PM
needs some help... back window not working systemstech2006 Camry/Camry Hybrid/Vista 3 01-05-2006 07:37 PM
Help!!! Galant will not start... shaunmc Galant 2 10-12-2005 11:07 PM
87 crx will not start wen hot outside sleeper87si '71-'87 Civic | CRX 3 09-05-2005 12:46 PM
