Old 11-24-2003, 10:52 PM
91B16Civic 91B16Civic is offline
Front and Rear Lower Tie Bars (Lower Strut Bars)
Alright I'm having a bit of difficulty figureing out how these things actually attach. Well I think the first problem is I have the wrong bars, because the company sent me one for a 92 civic and I think they are too short. I was wondering if anyone had pictures of their lower tie bars so I can see where and how the mount up.
Thanks.
Old 11-24-2003, 11:17 PM
BullShifter's Avatar
Re: Front and Rear Lower Tie Bars (Lower Strut Bars)
Lower tie bars mount between(left/right) the lower control arms - usually using the same bolt.
Old 11-24-2003, 11:35 PM
I had to run to my car for some smokes, so I took a quick pic of my rear bar for you. Its fucking COLD then mofo.
that is Neuspeed rear lower tie
Old 11-25-2003, 05:43 AM
cool thanks.. that's where I thought it mounted.. yeah the bar they sent is def. too short.
Old 11-25-2003, 08:59 AM
Alright here is what mine look like. I attach the bar to the bolt in the far left hand side of the pictures, correct ? also can you show me the diff. between your LCA with a sway and my LCA without one. What mean is what is the difference in the LCA's ?
thanks.
Old 11-25-2003, 10:18 AM
Here a shot of the rear LCA on my '91 Si. As you can see there is an open hole on the top side, thats where the Si rear sway would mount to.
Old 11-25-2003, 10:52 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Old 11-25-2003, 11:16 AM
thanks guys. I'm gonna try to see if I can't get the bar they sent me to fit. These pictures really have helped out a lot. Not to be needy but do any of you have pictures of your front lower strut bar install ? There is really only one place that i can see it fitting, but with the bar being too short I just wanted to make sure I was looking in the correct location.
Old 11-27-2003, 09:46 AM
Alright I got the lower one mounted up, thanks to your pictures. I went do the front one and realized that in order to get the hood to close the guy I bought the car from lowered the engine and therefore the Axles are right in front of the control arms and I would have zero clearance between the tie bar and the rotating axles.. therefore I opted against putting it on. But thanks again for all your help.
