Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-24-2003, 10:41 PM
HONDABOND HONDABOND is offline
B18c1-vortec=?(loooong)
Here is the deal, I am going to sell my 90dx hatch and move on to a 92 hatch and I am getting kicked down a B18C1 that needs to be rebuilt from my frend (Going typeR in his gsr) The motor is OBD1 and has a little over 180,000 miles on it and needs to be rebuilt do to a snaped timing belt (Bent valves fubar guides posable fubar piston) the motor is running cool right now but has a compression leak on the #3 cyl and its no longer making the power.
So my plans are to buy the 92 hatch and use the motor untill I have completed the rebuilding of the gsr engine, now, before I continue, I live in the bay area (California) and I need this car to be 1.Fast 2.Fun with awsome handles 3. Totaly legal and easy to smog... So going balistic on the engine is not an option... I am basicaly planing for 10.0:1 FI wiseco pistons and crower rods because this wont mess with my emissions (will need to see a smog reff so I need this to be all legit, I got 94 usdm ecu trany and motor all from the same car) I may use a slightly thicker head gasket to achieve a 9.5:1 ratio but no lower than that or it could spell trouble at the emmisions station. The head is going to be rebuilt with all skunk2 products (Except cams, gears and intake manifold. Those will wait for after break in) of course the engine will recieve new bearings and all the love it deservs before being thrown in the car, after smog it will get the skunk2 manifold, gears, some cams (Not sure which yet) and eventualy (When I scrape up enough cash) a Vortec centrifugical supercharger kit (The B16 Aftercooled one since I will be using the skunk2 manifold). So the questions are:
1. How much power will a fairly modified B18C1 vortec supercharged and intercooled engine make @ 8-9 psi, I see on there site there stock gsr put down 248whp with the aftercooler unit. I want to break 300whp and still be legit, doable?
2. I know there is some way to upgrade these superchargers, anyone know anything about it?
3. Does anyone know what kind of cams work well with a centrifugical supercharger?
Thanks for reading my story.
White folk eat noodles too.
Old 11-27-2003, 09:22 AM
PWMAN's Avatar
PWMAN PWMAN is offline
While most people will say go with a turbo, I say stick with the SC. All this crap about the crank loss driving the SC is BS. On a 300 HP honda you might loose 10 HP, and the fact there is no turbo lag I would take that loss. Centrificals are so advanced now, with technology, that they are taking over in the market.
I own a turbo car (dodge Daytona) and turbo lag sucks big time. And thats with 2.2L, your car is only going to have 1.8.
You can upgrade SC's by changing the pulley, so it makes more boost. With 9.5:1 compression, you can probably run about 12 PSI on pump gas 91 Octane.
That 248 WHP, is probably with the STOCK exhaust system. That is SO restrictive. Just putting on a header and 2.5'' high flow exhaust should get you to the 275 WHP mark. Then up the boost to 12 PSI and you should be well over 300 WHP. Plus cams and that other stuff you should be around 325 WHP total running 12 PSI. With that kind of power you should look into an LSD, a really good clutch + flywheel, and really strong axles.
Old 11-27-2003, 11:59 AM
boosted331 boosted331 is offline
Re: B18c1-vortec=?(loooong)
No turbo lag? If you think a dodge daytona with a tiny-ass T3 has lag, you would want to hang yourself after driving a centrifugal car. A centrifugal takes till redline to make full boost. Centrifugals make NO torque. Centrifugals have a powerband that sucks ass compared to a turbo. Centrifugals make soo much power, that's why all the fast hondas are running them, right? The ONLY fast centrifugal cars are domestics, because they run lower redlines so they can run smaller pulleys and get more low-rpm boost. They also have a lot more displacement to make up for the lack of low end power. Don't forget belt slip you're going to get running a tiny 4 or 6 rib pulley, how much of a pain in the ass it is to change pulleys, how much of a pain in the ass it is to keep replacing belts, and once again how annoying it is to have no low end power.
Old 11-27-2003, 12:11 PM
civic15.8's Avatar
civic15.8 civic15.8 is offline
i think that vortech superchargers just suck on honda and acuras i think that they should just stick to domestics but that is just my 2 cents
95 integra ls
kyb agx adj shocks
ground control coilovers
I HAVE JUST BEEN TURBOED
future:
str intake manifold
17" rims
apex n1 exhaust
body kit
carbon fiber hood
We need more members: www.hondachat.com
Old 11-27-2003, 12:51 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
10 hp? heres a desciption and definition of parasitic loss from honda/acura performance, "Parasitic Loss- A turbo harnesses this wasted energy to drive the compressor. Other compressors, such as superchargers, use a crank-driven pulley as a source of power. Though this loss can very low in low boost situations, the trouble is, supercharging can use up to 80 hp to produce the high boost levels needed to produce the awesome power these engines are capable of producing. This 80 hp is taken right off of the crank and subtracted from the total amount of horspower the engine produces. The loss of power caused by superchargers is called a parasitic loss " (1999, p86).
Old 11-27-2003, 01:52 PM
PWMAN's Avatar
Re: Re: B18c1-vortec=?(loooong)
It has a pretty big turbo for a 4-banger.
Honda's are the best cars to put centrificals on because they rev so high. The reason ''fast honda's aren't running them'' is because turbos have been around awhile but good centrificals haven't. Procharger is probably the best.
You can get a really small pulley to make full boost before 4K RPM, and have the BOV act as a wastegate and bleed off boost once it reaches whatever PSI you want to run.
And what are you talking about changing pulleys? Once and done. And belt slip is a thing of the past. It's called technology, they fixed all the old mistakes. Procharger has 8 rib belts.
Old 11-27-2003, 01:54 PM
PWMAN's Avatar
Yeah 80 HP if you are making over 1000 HP to begin with. And even at those levels, the turbine in the turbo is probably restrictive enough to take 80 HP away. That was probably taken from a roots blower anyway, they cause a lot of crank HP loss. Centrificals are way better. Yes 10 HP.
Old 11-27-2003, 03:05 PM
tran_nsx's Avatar
Re: Re: Re: B18c1-vortec=?(loooong)
please show me a 1000 hp s/c honda? how many 9sec hondas u know are using s/c? a guy wrote an article on the increase of hp he gained after installing a jacksonracing s/c on his b16 si. it an was increase of 35-40 whp after parasitic loss, vey dissopointing especially when he could spent the same amount on a t/c kit and gain double the power if not more than that amount. a rev hard t/c kit on a civic si jump to 252whp and 228 lbs of tq at 7 psi let me see a s/c do that. the main drawback with turbo is the lag. also turbines does not remove 80 hp, the only problem where the turbine becomes an issue is went it is bigger causing an increase in lag time, but this wii be able to create substantially higher hp gains due to it's increase in air compression.
i know u prefer s/c over t/c, but clearly for f/i applications on hondas,
turbocharging is clearly the best route if u want power. iv'e met people who installed s/c on thier vehicles and they were actually unsatisified if not dissopointed with thier results, some of them sold their s/c to get a t/c. of course some people elsewhere might be happy with the modest gains, i know i won't be.
10 hp please, show me your proof, sounds to me like it's your own theory.
Old 11-27-2003, 03:42 PM
PWMAN's Avatar
Re: Re: Re: Re: B18c1-vortec=?(loooong)
please show me a 1000 hp s/c honda? how many 9sec hondas u know are using s/c? a guy wrote an article on the increase of hp he gained after installing a jacksonracing s/c on his b16 si. it an was increase of 35-40 whp after parasitic loss, vey dissopointing especially when he could spent the same amount on a t/c kit and gain double the power if not more than that amount. a rev hard t/c kit on a civic si jump to 252whp and 228 lbs of tq at 7 psi let me see a s/c do that. .
Like I said SC's are just starting to get into the swing of things.
I could have told you JRSC's suck balls. And I already said roots blowers have the most crank HP loss.
Dumbass, the guy in the beginning said himself that the Vortech kit gives 248 WHP, is that not close enough to 252 for you?
Old 11-27-2003, 03:45 PM
PWMAN's Avatar
Oh yeah the Procharger kit for the 99-00 SI is capable of 40 PSI. That can make 800 HP, but thats probably not close enough to 1000 for you.
Old 11-27-2003, 04:05 PM
PWMAN's Avatar
http://www.procharger.com/honda.shtml
''largest power gains available for Honda applications''
Old 11-27-2003, 04:53 PM
If you think a T3 that will support 300HP, tops, is a big turbo for a 4-banger you're a crack addict. The turbos supplied in ALL turbo kits (greddy, rev-hard, max rev, drag, etc) are all a fair bit larger than a T3, and nobody complains about spool problems with them.
Please, elaborate on this. Hondas are THE WORST to put them on because they have no torque to begin with, and the centrifugal doesn't help them at all in that department. Take a look at a 350 WHP vortech dyno here. Wow, peaks at 220 ft-lbs to the wheels and doesn't exceed 300 WHP untill 7500 RPM's. Hell yeah man, that'll make you go faster than a turbo
The reason fast hondas arn't running them is because they won't make them any faster. Vortech's kit has been on the market for about 2 years, procharger atleast a year. That's MORE than enough time for a race team to get their shit together and use one, if it was going to make them faster. The AEM EMS has been out as long as the vortech kit, and yet lots of people are using those. Nah, you're right, it's because centrifugals havn't been on the market very long Yeah, procharger is the best. If you can get over the massive issues they've had with their head units leaking oil and seizing up. Minor issue though to get rid of turbo lag though, right?
Not a chance. You could never run a pulley small enough to give you sizeable boost @ 4000 RPM's on a serpentine system. Cogs with a huge crank pulley, maybe. Otherwise no. Having a BOV vent off excess boost would do you diddly, the power gains you might get by having boost down low (if the system would even work in the first place, which it wouldn't) would be offset by all the extra power you're still taking to drive the supercharger faster.
Once and done? Please. Somebody is going to roll around on whatever setting for the entire time they have their blower. Nobody wants to run more boost on race gas at the strip or turn it down if they can't get premium whereever they are. And belt slip is a thing of the past, give me a fucking break. You've never owned a centrifugal, you go buy whatever other mindless idiots like yourself make up on the internet, you have no idea about belt slip. I don't know for sure what kind of a pulley system the prochargers for hondas ship with, but I can guarantee it isn't an 8-rib. Vortech sells theirs with a 4-rib, and a lot of base model V8 procharger kits designed to run smaller pulleys than the honda kits come with 6-rib drive systems, so I find it VERY hard to belive the procharger kit comes with an 8 rib drive.
And your last post "http://www.procharger.com/honda.shtml
''largest power gains available for Honda applications''"
Gee, that's such a shocker to see coming from the PROCHARGER WEBSITE! Even if prochargers did make more power than turbos, have you heard of anything such as area under the curve? Low end power? Guess not.
Old 11-27-2003, 05:45 PM
tran_nsx's Avatar
Re: Re: Re: Re: Re: B18c1-vortec=?(loooong)
so now your comparing a b18 to a b16? even stiil it's making more power at a lower boost, oh and this is only their first stage kit. im really getting bored of these theories and claims, until u get me some real dynos then we can continue.
Old 11-27-2003, 05:55 PM
PWMAN's Avatar
Procharger V8 kits you can get with up to 12 rib pulleys. The Honda one has 8 ribs. I ordered catalogs from them, I got all the info about them. The head unit can handle 40 PSI, capable of 800 HP. And yes it's an 8 rib pulley, so go stuff it.
Procharger is much better than Vortech, they got their shit together. Everything about them is professional. When I ordered their catalogs, they send it first class mail and I get it 2 days later. I have not found any other company to do that, if they even sent the info in the first place-most don't. Anyway, my point was that ATI is better than other companies.
Yes I agree that you will still have less torque than with a turbo, but torque isn't really needed in such light cars. If you had identical cars, say GSR's, one with that 350 HP and 220 F/P's, and one with turbo with 300 HP and 300 F/P's, I think the SC'd one would win. Because once you are out of first gear, there is no more low RPM power to worry about. Plus the turbo lag of the other car will give you a chance to get ahead and the turbo guy is just playing catchup.
My point was that 50 more HP on the top end will yield better results at the track than 80 more F/P's of bottom end torque. Because, again, once you are out of first gear the only RPM's all you have to worry about is 6500-8000 RPM which is where the SC really makes it's power anyway.
Old 11-27-2003, 06:06 PM
PWMAN's Avatar
Re: Re: Re: Re: Re: Re: B18c1-vortec=?(loooong)
Increasing displacement doesn't do much for HP, some but more so for torque.
So, here is your dyno results. I couldn't find any at the wheels but I think the 278 BHP is just about right for 248 to the wheels.
http://www.superchargersonline.com/p...=V4HC218-040SQ
